Kingston HyperX DDR3 CL9 2000mhz 3GB Triple channel kit
Ubisoft has developed a new engine specifically for Far Cry 2, called Dunia, meaning “world”, “earth” or “living” in Parsi. The engine takes advantage of multi-core processors as well as multiple processors and supports DirectX 9 as well as DirectX 10. Running the Far Cry 2 benchmark tool the test was run 5 times with the highest and lowest scores being omitted and the average calculated from the remaining 3.
Â
Â
Results conclusions
Again the faster Kingston took the advantage and beat the Corsair throughout the tests. Despite the Corsair having lower timings, the higher bandwidth of the Kingston HyperX showed it is not worth the 6GB if it means sacrificing speed.
Let’s head over to the conclusion…
