Kingston HyperX PC3-11000 CL7 DDR3 2gb Kit
Test Setup, Settings & Overclocking
Published: 11th September 2007 | Source: Kingston | Price: £280 |
Being the first DDR3 memory review here at Overclock3D the Kingston HyperX PC3-11000 kit will be reviewed as a standalone product using the hardware specified below. However, as further DDR3 reviews are added to Overclock3D, the results from these reviews will be included on the graphs shown over the next few pages.
| Kingston HyperX PC3-11000 | |||
| Processor | Intel Core2Duo E6850 | ||
| Motherboard | Asus Blitz Extreme (P35) | ||
| Graphics Card | BFG 8800GTS 640mb OC2 Edition | ||
| Hard Disk | Hitachi Deskstar 80GB 7K80 SATA2 7200RPM 8mb | ||
| CPU Cooling | Stock Intel Aluminium Cooler | ||
| Operating System | Microsoft Windows XP (SP2) 32bit - Latest Patches | ||
| Memory Frequency* | 687mhz (DDR2-1375) | ||
| Memory Latency* | 7-7-7-20 | ||
To guarantee a broad range of results, the following benchmark utilities will be used:
• Sisoft Sandra XI SP2 (CPU, Memory & HDD tests)
• SuperPI Mod v1.4 (1m and 16m)
• Cinebench 9.5
• HDTach 3.0.4.0
• Quake 4
• Counter-Strike:Sourc
• F.E.A.R
• 3DMark05
• 3DMark06
Memory Settings & Overclocking
As with all memory reviews on Overclock3D the HyperX PC3-11000 modules were subjected to a series of benchmark tests under several different configurations. The configurations used tested the memory's ability to run at high frequencies, tight timings and also ensured that that the modules could run with 100% stability at their advertised stock settings.
Stock - 1375mhz / 1.7v / 7-7-7-20
It is an unfortunate fact that many memory modules we've tested here at Overclock3D in the past have fallen at the first hurdle by not being able to run at the advertised stock speeds. Therefore as part of our standard testing procedure, all memory modules are subjected to extensive stability testing using Prime95 and SuperPi.
Thankfully the Kingston HyperX PC3-11000 kit did not suffer with this problem, managing to run at the advertised settings of 1375mhz / 7-7-7-20 / 1.7v without any stability issues whatsoever.
Low Latency - 1375mhz / 1.8v / 6-7-7-20
Bumping up the voltage to 1.8v allowed for the modules to be tightened down to 6-7-7-20. Unfortunately any attempt to further reduce the latency down to 6-6-6-20 or 6-7-6-20 including increasing the voltage to 1.9v yielded no success. I can only assume that the Elpida IC's used on the HyperX kit do not respond well to increased voltages and/or tight timings.
Max Frequency - 1472mhz / 1.8v / 9-9-9-20
With the voltage still set to 1.8v and the timings relaxed to 9-9-9-20, the furthest the HyperX kit could be overclocked to while still maintaining stability was 1472mhz. Unfortunately, as this is the first DDR3 review conducted on Overclock3D it's hard to comment on how this 97mhz overclock compares to kits from other manufacturers.
Very good write up, Jim!
But the timings seem to lose at the moment... Stick with DDR2 until DDR3 price drops a little and they sort out those timings!
Thanks!
Thanks!
Timings! Did you learn nothing from this lol.
Goes off to read review...
Edit: Well, they are very average aren't they. I think you should remove 'Reasonable performance' from 'The Good' and add it to 'The Mediocre'. Reasonable does not strike me as a good attribute.
Good review though, just average sticks
Fantastic wirte up as usual jim.
Im forced too ask: how are they conning us this time? With DDR3 overall. we multiplying the REAL fsb by what? 4? 6? 8?
Don't get me wrong im all for progress, i just like too be able too see through marketing.
http://www.overclock3d.net/gfx/artic...144558599s.jpg
HyperX PC3-11000 Review
