Mushkin PC10666 Low Voltage RAM Review
Search Reviews
We recently reviewed the Mushkin Redline DDR3 kit and found that not only was it a thing of beauty and performed well at stock settings, but it also was an overclocking beast. The Ridgeback heatsink being both low-profile to fit under our test Noctua NH-D14 cooler and also high-performing with the RAM cool even highly overclocked.
This got us to thinking. If their high-performance RAM is exceptional, then maybe their low voltage RAM will be good too. After all we've seen a few low voltage kits pass through our doors and all of them were surprising in their level of performance and ability to overclock.
Mushkin have a very low latency, low voltage 6GB kit available so we just had to see how it faired.
As you can see with an operating voltage of only 1.5v there is a cut down in speed when using the primary XMP profile with the RAM being rated as 1333@7-7-7-20.
Low latency timings and some voltage headroom should at least see us able to push onwards a bit, but how far?
Model: 998955
Type: DDR3
Pins: 204
Voltage: 1.5V
Speed Spec: PC3-10666
Frequency: 1333MHz
Kit Quantity: Triple Kit
Module Density: 2GB
Module Config: 256x64
Ranks: 2
tCL: 7
tRCD: 7
tRP: 7
tRAS: 20
Heatsink: Ridgeback
Onwards to have a look at the RAM itself.
«Prev 1 2 3 4 5 6 7 8 Next»
26-10-2010, 04:28:05
tinytomlogan
Following the excellent performance of their Redline RAM, we just had to take a look at the Low Volt Mushkin RAM.
Continue Reading
26-10-2010, 14:37:20
SnW
Nice timmings and voltage
26-10-2010, 17:50:25
Sihastru
Nice review. And I must say the Ridgeback heatspreaders look amazing.
But quick question. You seem very amazed at the fact that the kit can do 7-7-7-20 @ 1333MHz 1.5V. But I'm doing that right now with some very cheap 6GB Kingston value RAM, that was rated at 9-9-9-25 @ 1333MHz 1.5V and it's even 1T CMD rate. I don't even have heatspreaders on them. Am I really lucky here or is this something any kit can do @ 1333MHz? Of course I can't do more then 1600MHz 1.65V so that's where the Mushkin kit goes stratospheric.
27-10-2010, 12:42:39
Alicarve
good review
just an edit for you though on page two you missed the h in though and added an a
We much prefer the stealthy appearance of the Ridgeback to some of the more "shouty" designs we've seen. It's a nice tough to see a Mushkin logo on the top face of the DIMMs as this is where it will actually be visible.
