Antec Veris Multimedia Station Premier
Installation
Installation
Installing the Multimedia Station should have been easy: 'should' being the operative word. Unfortunately the chassis which currently houses my pc has small air intakes between each 5 1/2" drive bay, making it impossible to slide in the double height Multimedia station. This is something you will need to bear in mind before you buy - check to make sure you have a case with 5 1/2" bays directly next to eachother, with no gap in-between.
The first stage of installation involves installing the 24pin pass through. This cable allows the Multimedia Station to draw off the PSU's 5v stand by power rail, in turn allowing it to display the time even when the pc is turned off. You need to install the pass through between your PSU and Motherboard, then run the group of three wires to the drive bay and put the plug into the socket located on the small PCB (Left Picture).
 Antec Multimedia Station ATX cable Antec Multimedia Station Back
The next step is to wire up the USB so that the Multimedia Station can communicate with your computer. There are two ways of doing this; you can either run the USB lead out the back of your case and into a standard USB port, or use the included adaptor to connect directly with a motherboard header. The power switch will also need to be wired into the device, which will allow you to boot your computer via the included remote. To do this you wire your case's current power switch into the Multimedia Station's PCB, then take the new power switch lead from the PCB to your motherboard - Voilà, hardware installation is complete.
Antec Multimedia Station USB adaptor Antec Multimedia Station Power SW
Once the hardware side of the installation is out of the way, you will need to boot up your pc and begin the software installation. Installation is fairly quick, and after a restart you are ready to go. Before going into the media handling side of things, you will need to setup the display. This involves selecting which remote you will be using, what you want the display to show and setting up RSS feeds and Email accounts. All of this is fairly self explanatory, but can be a bit daunting with the wealth of options. Once you get to grips with what each button does though, it doesn't take long to setup.
 iMon setup
Before looking further at the media side of things, I thought I would take a look at what sort of system information the display can handle. I was expecting something similar to Logitech G15, displaying ram usage, maybe a temperature or two and CPU usage. I was wrong;  instead it just scrolls through your system specs, with things like "Windows Vista Home Premium" and "Intel Core 2 Quad Q6600". Not willing to give up, I fired up Everest as this worked incredibly well with my G15, but alas, it wasn't compatible with the display. For the enthusiasts out there, I'm sure someone will find a way of doing it, but until then, looking at detailed system information is off the cards.
Here are some shots of the Multimedia Display showing various bits of information.
 Antec Multimedia Display System Information
Time - System Information
Antec Multimedia Station System Info Antec Multimedia Station Itunes Information
System Information - iTunes
Having looked at the device up close, it's about time we had a look at the bundled software. Head on over to the next page where I take a look at the iMon software.
«Prev 1 2 3 4 5 Next»
30-06-2009, 16:59:29
Luigi
Looking to jazz up the front of your pc, or turn it into a HTPC? Maybe the Antec Veris Multimedia Station Premier is for you.
http://www.overclock3d.net/gfx/artic...185903215s.jpg
Read the full review here.Quote
30-06-2009, 17:13:34
Msm2
A very good review,been looking at the Veris for a while. After reading this review I will be buying one in the near future.Quote
30-06-2009, 17:15:31
zak4994
Nice review as usual.
Not all Aluminium so be careful there. Quote
30-06-2009, 17:19:44
Msm2
A real good look (in the flesh) at the front panel first.Quote
30-06-2009, 17:21:18
Luigi
I have to say it doesn't look cheap, and looks good for plastic. However, if you have an alu case it just wont look as good.Quote
30-06-2009, 17:22:10
zak4994
Was what I was trying to say before.Quote
30-06-2009, 17:31:58
Msm2
Antec300 case may look ok.Quote
06-07-2009, 04:54:39
mayhem
been reading though this a couple of time now.
Ive come to the conclusion a £70 7" lcd touch screen is still a better option.
when you consider the fact that the lcd screen isnt compatible with any other software and to be honest is quite a old technology and why do you need it to tell you you have an email when there is plenty of free software that will do that any way.
All so consider what it is, its not really that good. You could chop that down to 1 bay and lose the knobs off it as really who in the modern day world is going to walk over to it and start pressing buttons and fiddling with knobs when they have a remote. If they removed that section and just left the LCD and IR receiver and dropped the price By £20 it would make it worth while.
Looks to big and clumsy in its present form.Quote
06-07-2009, 05:23:48
Luigi
There is one you can get without the dials and buttons, which is also cheaper, however, I'm not sure how much cheaper.
I agree that perhaps people aren't going to walk over to their Case, but for £70 the Veris is still a cheaper alternative to replacing your current case with a HTPC case.
It's worth remembering it comes with a remote as well, which is where a normal 7" LCD can't compete.
Quote
06-07-2009, 05:30:14
mayhem
to be honist i may disagree as i just check lillput's prices on a 7" tft touch screen and you can now get one for £60 then throw in a Windows remote £10 to £15 and you are sorted for £75.
again a much better option. the only downfall is that you will need to mod it. But that's the difference this is a pre bought option. I keep forgetting that.Quote
06-07-2009, 05:35:58
Luigi
Yeah, for people like you that certainly sounds like a good option to choose, however, not everyone is a techno wizard like you- shame on them!Quote
06-07-2009, 05:49:22
mayhem
Im no technology wizard lol. Just ignorant to people whom by pre bought things .. Need to consider that next i think.Quote
