HEC Compucase Cougar 1000CM Modular PSU
Introduction & Specifications
Published: 23rd October 2009 | Source: HEC | Price: £147.08 |
I'd like to think that we've covered quite a wide range of PSU manufacturers here on OC3D over the past few years, but every once in a while a new review request drops into our inbox from a company that has been in the industry for an eternity, yet never really fallen under the Overclock3D radar. HEC Compucase is one such company, and founded in 1979 HEC Compucase originally started out life manufacturing metal sheet components for the automotive industry. However, almost 10 years later this knowledge was applied to PC chassis manufacture which was soon to become their primary focus.-Supports the newest specifications of ATX12V & EPS12V
-Created for usage with current and next-generation multi-core CPU and GPU platforms
Green Design for Energy saving
-80plus® certified, environmentally conscious green product design for lower energy consumption
-Meets Energy Star requirement - Standby (Off mode) <2W, Sleep mode < 4W
-High efficiency: Up to 87%
Ultra quiet
-Extremely Low Noise Level at < 23dB
-Ultra quiet 140mm fan with thermal control function. Keeps the Cougar cool and quiet at all the times
Efficient and stable component architecture
-Six independent and stable +12V rails promote the best performance to gamers
-High-end industrial grade capacitors provide more electrical power storage to promote higher efficiency and longer product lifespan
-With Active-PFC (PF>0.99) at 100% loading and Universal AC input (100-240Vac Full Range)
Modular Cable Management
-Modular cable design allows you to detach connectors freely and use only the cables you need
-Smart plug design: cable connectors are designed to connect to their proper input only
Full safety protection
-Full Protection: OCP, SCP, OVP, UVP, OPP
-Safety and EMI certified: CB, TUV, CE, UL, cUL, FCC, MIC, BSMI
| HEC Compucase Cougar 1000CM Rail Layout | ||||||||||
| DC Output | +3.3V | +5V | +12V1 | +12V2 | +12V3 | +12V4 | +12V5 | +12V6 | -12V | +5VSB |
| 30A | 30A | 20A | 20A | 20A | 20A | 20A | 20A | 0.8A | 4A | |
| Max Power | 175W | 960W | 9.6W | 20W | ||||||
| 1000W | ||||||||||
Originally Posted by name='Socks'
shame he didnt destroy it... Horrible results for such a costly piece of hardware...
Luckily the OCP/OPP kicked in before anything went "POP" every time. So at least the safety is there.
looks over performance = FAIL!
Dear James,
Firstly I would like to thank you and Overclock3d for reviewing our Cougar power supply posted 23rd October 2009. Admittedly it was not the kind of review that we were hoping for nor expecting.
Action had to be taken by Compucase HEC, this industry relies heavily on reviews and word of mouth, for us to not do anything was unthinkable, therefore the review went directly to our R&D department and the product manager in Taiwan where they took the review apart paragraph by paragraph.
The good news is a revised version will be going into production next week of the 1000w, that will address the ripple issue that you highlighted as well as some other smaller points you brought to our attention.
I firmly believe this has been a worthwhile exercise that has allowed us to revisit, review and correct the issues you highlighted, we wanted to demonstrate the level of support you could expect from Compucase HEC, being the “new kid on the block” (excuse the pun) we have to work that little bit harder to prove ourselves.
Mark Szachno
Compucase UK Ltd.
Furthermore, Compucase have also agreed to send us a revised unit when they are available.
Now where is that XFX reply........? Nope cant find one.
Its not often in this day and age that a manufacturer would actually listen to a review and even let the R&D dept know of the findings so pre production changes can be tweaked.
money spent pre production will save on warranty exchanges and give a "new kid on the block" a far better reputation.
Better to be known for reliability than have a good RMA service imo.
Good on you Compucase HEC.
As Tom mentioned, XFX come out of the shadows , we know you are watching, too ashamed perhaps?
Or maybe they are too busy attempting to fix their PSU as we speak.
XFX's name is too good to be tarnished so they can not leave this behind.
That Version has solid caps on the VRM for example and looks a little better, as you can see There planet3dnow.de/vbulletin/showthread.php?t=368324&garpg=4
The primary cap for example is a 105°C Nippon Chemicon over here...
I hope you can review the fixed version soon...
Originally Posted by name='Stefan Payne'
I wonder why they didn't send you the better equipped German Version of the Cougar CM 1kW.
That Version has solid caps on the VRM for example and looks a little better, as you can see There planet3dnow.de/vbulletin/showthread.php?t=368324&garpg=4 The primary cap for example is a 105°C Nippon Chemicon over here... I hope you can review the fixed version soon... |
EDIT: Although its hard to see from the picture on their site, it does look like the unit still has a really weak amount of caps on the secondary side.
Originally Posted by name='Jim'
That is very interesting, thanks for bringing that up. Does indeed make me wonder why they decided to send us that model, especially when they knew the kind of equipment we'd be testing it on.
I don't know why the lineup of PSU from HEC/Compucase UK is completely different to the rest of Europe...
You may want to take a look at cougar-world.com.
EDIT: Although its hard to see from the picture on their site, it does look like the unit still has a really weak amount of caps on the secondary side. |
Would it make any difference if some of the caps were polymers?
Originally Posted by name='Bungral'
Jimbo, ya know if they are gonna send you a revised sample when made?
I hope it'll be soon.
I'd think that the Chief of the Cougar label wasn't happy at all...
Compucase have responded to the review with the following statement:
Furthermore, Compucase have also agreed to send us a revised unit when they are available. |
Looking forward to the re-review
Originally Posted by name='monkey7'
1 character -.-
Continue Reading
