OCZ Z-Series Z1000M 1000W ATX PSU
Introduction & Specification
Introduction & Specifications
 Fraction of Rated Load  20%  50%  100%
 80 PLUS  80%  80%  80%
 80 PLUS Bronze    82%  85%  82%
 80 PLUS Silver    85%  88%  85%
 80 PLUS Gold    87%  90%  87%
Back at the beginning of 2008 PSU efficiency organisation 80PLUS revised their certification program to include three new standards on top of the original 80PLUS (80%+) certification. The Gold, Silver and Bronze levels introduced new efficiency targets for PSU manufacturers to meet in an effort to reduce global energy consumption in PC's and other devices. While none of these new certifications were by any means mandatory the PSU market (in terms of PC's at least) is immensely competitive, and having a PSU certified to one of these new standards would be a sure-fire way to attract the energy conscious consumer who is looking to save money on their electricity bills while also doing their little bit for the planet.
So the race was on. First to 87/90/87% efficiency at 20/50/100% load levels gets the gold medal!
But manufacturing a PSU that is capable of delivering 90% efficiency is no easy task by any stretch of the imagination. On a 500w PSU running at full load this would mean less than 50w finding its way out of the unit as heat from the components. This is in contrast to the 100w of wastage by an 80% efficient 500w PSU running at the same load. In most cases it would take a complete re-design of an entire PSU along with stringent checks of each and every component used inside. As a result very few PSU manufacturers to date have actually be able to achieve gold status, instead settling for the runner up medals of silver and bronze.
So, why the big efficiency speech I hear you say? Well today I'm going to be taking a look at the latest PSU from well known performance DDR and SSD manufacturer OCZ Technology. Branded the Z-Series and available in 850w and 1000w models, this is THE FIRST PSU to pass through the OC3D labs with a shiny gold 80PLUS sticker on it's packaging. Impressive, yes? Well let's just wait and see. But first, the specifications taken from OCZ's website:
OCZ Z Series Gold / 1000W / SLI-Ready / Active PFC
True to our enthusiast roots, OCZ Technology designed and developed the Z Series for power users searching for nothing but the best. Paving the way toward the most efficient means of achieving high-end performance, these PSUs feature ultra-high efficiency of 90% and have achieved the 80+ Gold Certification. OCZ strived to make the Gold Z Series a true “best-in-class” power supply, including a powerful single +12-volt rail design and an industrial-grade core engineered for maximum stability and reliability. Built for excellence, the Z Series raises the bar in power management and provides an unparallelled solution for enthusiasts who won’t settle for anything less.
Powerful
Delivering 1000W of continuous output and utilizing a high-performance architecture, the Z1000 provides rock-solid power for the systems of gamers, enthusiasts, and power users. With a peak wattage of 1100W and a single +12V rail (83A) design, the Z1000 doesn’t put limits on your system the way competing PSUs do.
Ultra-Efficient
High-performance doesn’t need to translate into over-the-top energy use. With an ultra-high 90% efficiency rating, the 80 Plus® Gold certified Z1000 power supply offers ultimate stability without driving up your energy costs.
Industrial-Grade
The Z1000 is tested and certified at industrial levels (50°C) to provide the ultimate powerhouse for those that require long-lasting, industrial-grade components for their mission-critical system or cutting-edge gaming machine
Premium Cooling & Acoustics
Powerful yet cool, the Z1000 maintains ideal temperatures and superior air flow thanks to a large 135mm double ball bearing fan that adapts to the system’s load and thermals while remaining ultra-quiet at high speeds.
Active PFC
Each Z1000 features Active PFC (Power Factor Correction) to regulate input voltage and deliver premium sag and surge protection (.99PFC), allowing for effective distribution of power in a wider range of environments and varying voltages.
Multi-GPU Ready
Equipped to fuel the demands of gaming systems, the NIVDIA® SLI™Certified Z1000 solution has an array of connectors and the stable output to power dual GPUs—an essential element of top gaming builds.
OCZ 5 Year Warranty
Premium power supplies deserve the finest warranty available, and OCZ stands behind the Z1000 with its 5-year PowerSwap warranty for ultimate peace of mind. No more endless return-for-repair loops!
There's absolutely no doubt in my mind that OCZ can talk the competition into submission, but how about when we peel back the layers of marketing spiel. Well to start with we have of course the all-important 90% efficiency. There's no mention of whether this is achievable at all load levels, but we can be sure that it has at very least met the 87/90/87% requirements of the 80PLUS Gold certification.
Then there's the 50°C "Industrial-Grade" testing. This essentially means that the Z-Series can deliver its full rated output while sweating it out in a poorly ventilated chassis. Very good to know, as the Z-Series is going to get a full roasting in our hot-box later on in the review.
OCZ Z-Series 1000w Rail Layout
DC Output +3.3V +5V +12V1 +12V2 +12V3 +12V4 +12V5 +12V6 -12V +5VSB
25A 25A 83A - - - - - 0.8A 6A
Max Power 180W 1000W 9.6W 30W
1000W (1100W PEAK)
Moving on to the rail layout it's hard to miss the stupendously powerful single +12v rail rated at 83A! This is the kind of layout that put PCP&C on the map with the enthusiasts, so its interesting to see OCZ taking a leaf from their book. Both the +3.3v and +5v rails are rated at 25A with a combined output of 180W which is about average for a 1000W PSU, and the only other real area of interest is the +5VSB rail which is rated at 6A - around 2x higher than most other PSU's.
Now let's move on to the appearance of the Z-Series...
«Prev 1 2 3 4 5 Next»
10-09-2009, 08:46:43
JN
"Today we take an exclusive first look at OCZ's 80PLUS Gold certified Z-Series Modular PSU. Can it hold its own in the OC3D labs? Read on to find out..."
http://www.overclock3d.net/gfx/artic...152531248s.jpg
OCZ Z-Series Z1000M 1000W ATX PSUQuote
10-09-2009, 09:14:23
monkey7
You forgot the delta in the deltaTemp column header of the results table
why do I even see that O.o
Aside from that, great unit for high end rigs. Bring on the next gen graphics cards Quote
10-09-2009, 09:15:29
Freak
I was taken back by the amount of amps that were on the 12 volt rail.Quote
10-09-2009, 09:25:02
VonBlade
Impressive bit of kit. So many good products being released lately that we're almost starting to need a "OC3D top three recommendations" for catergories
Btw, did I miss the noise results? 100+cfm @ 30db sounds too good to be true.
Like the aluminium finish, just wish manu's would stop slapping big-ass stickers on them. We know what it can do, we've already brought it. Yeesh.Quote
10-09-2009, 09:28:40
JN
Good spot. The stupid wysiwyg editor keeps stripping those out randomly
Yeah even I was pretty impressed by how much that unit was pumping out, especially for its size.Quote
10-09-2009, 09:35:17
JN
I dont really like to make any official noise comments on PSU's these days, but in the new 'Performance Overview' chart there is a 'Noise' section which I rate at either Low, Med or High based on how noisy it sounds at full load with my ear pressed against it.
The Z1000M certainly sounded low - in fact it hardly seemed to increase the fan speed (or at least the noise associated with a fan speed increase) through any of the loads.
I'm looking into a fan bypass switch for the load testers so I can briefly turn the fans off for long enough to hear the PSU. Thing is, even the bloody oscilloscope has a fan in it, so its never going to be a perfect analysis.Quote
10-09-2009, 09:43:10
VonBlade
Thanks Jim. I know noise is stupidly subjective (I've got a 19db fan that sounds like a hurricane) but PSUs can be a source of noise it's impossible to rectify, unlike other cooling, so it's an important part in my decisions (which is still a HX series one).
Just a reasonable "loud, not so loud, is it on?" is absolutely fine, so thanks
I must have missed it in the performance chart. Overwhelming information lol.Quote
10-09-2009, 10:32:05
JN
Yeah if you're just looking for the low-down then the new overview charts is probably the way to go. It shows the percentage of voltage fluctuation from idle to full load (highlighting those PSU manufacturers that set their idle voltages really high to compensate for the amount of droop at load), Average efficiency and noise.
I'm also putting together a top 10 chart at the moment which will be sorted in order of performance for all PSU' I've tested in the last year or so.Quote
10-09-2009, 14:20:52
monkey7
What if you make a fan connection like used in psu's with a 5-12v pot and connect the fans to it? You're already ripping open the psu anyway.
Sure it would not be completely accurate and still be subjective, but together with your while-testing super subjective measurements it should be a little more precise.Quote
