Adaptec RAID 2405 SAS / SATA Controller
With less than a second between each of the Compression and Decompression results it looks like CPU performance may well be a bottleneck here as well. However, the combination of Adaptec 2405 controller + WD Velociraptor hard disks is at the front of the pack, showing that although the difference is small, there most certainly is one.
In contrast to the previous two benchmarks, Dummy File Creation uses up very little CPUÂ resources, instead concentrating on the array and filesystem write speed. Despite this, there is still very little difference between the Intel Matrix based RAID array (Array2) and Adaptec Array3 indicating that although our HDTune results put the Adaptec controller ahead of the Intel Matrix Firmware based array, there really is very little real world difference.
