Corsair Voyager Air 1TB Review
Up Close
Up Close
As you'd expect from Corsair the packaging is clear and easy on the eye. A simple specification table on the rear tells you everything you need to know.
Corsair Voyager Air 1TB Review     Corsair Voyager Air 1TB Review
Inside everything is nearly packed. Thankfully there is a wide selection of charging options available. You can just charge via a USB port, or with the wall-charger, or if you're on the move via the 12v car charging port.
The speediest charging option is via the DC port on the rear, and a cable is provided for that. There is also a USB 3.0 cable for connecting it as a standard external drive, should you wish.
The drive itself is compact and light. At 380g it is not a featherweight but not exactly heavy either. It's akin to a couple of smartphones, albeit slightly larger. Still you could stick it in a pocket and not feel weighed down by it, which is obviously important in a portable device.
At the rear things are as simple as you'd expect. DC for charging, USB 3.0 for charging/data transfer and an ethernet port for NAS duties.
At the front we have an on/off power switch and a WiFi switch. It's not complicated, but then it's only a drive.
«Prev 1 2 3 4 5 6 7 Next»
15-05-2013, 11:54:14
alienware
Thanks for the review Bryan, reading now Quote
15-05-2013, 13:21:40
dipzy
This was a great read, thanks Bryan
Drive looks great and with so many features that i would use daily, i will be picking one up soon hopefullyQuote
15-05-2013, 13:45:58
remember300
was a good read, thanks if they do it in blue id be tempted looks nice a chunky too, i know this sounds sad but i like a chunky drive makes me feel like my data is safe.
edit: in the intro just clear the double type of in the pub unless you go to a pub in a pub then thats awesomeQuote
17-05-2013, 07:28:27
Greenback
nice review and a nice bit of gear, My only concern would be how easy it will be to replace the battery, as they only have so many recharges before they don't hold the charge so long. And that will be long before the hdd is deadQuote
18-05-2013, 00:04:52
NeverBackDown
I want one now, in my rig i only have so much storage and this would most certainly help with my music library and other crap i have on here
The HUGE selling point is you can use this on WiFI or usb so if you have a smartphone with no unlimited data plan and you like to sync your devices for back up: you will not waste any precious data usage for that. Which is helpful if you have many music files,movies and etc...Quote
