Aria.co.uk Gladiator 1155 i5 4.4GHz Bundle
Our testing is normally at both stock, and the highest attainable overclock. As this is a pre-overclocked bundle we’re testing at the 4.4 GHz CPU speed it comes with. So there will understandably be a difference between the Gladiator and our other results as we normally hit around 5 GHz. So bear this in mind.
AIDA64
Utilising the latest version of the always updated AIDA64 the Gladiator performs very well in all the tests. PhotoWorxx is a little behind but that’s largely due to the RAM being slower than we normally test with. Otherwise there is a clear performance benefit to be had from the overclock when compared to the stock system.
Â
Memory performance is a fair bit behind the other systems we tested but, as mentioned above, you need to remember that most of the other tests were performed with very expensive 2000 MHz+ RAM.
