Aria Dominator 560Ti System Review
PC Mark Vantage
PC Mark allows us to test everything you’re likely to use your PC for, without needing to sit in front of it for months on end.
If anyone ever doubted the benefits that even a small SSD can have to your overall productivity need look no further than this graph. For capacity reasons our bench rig uses a standard mechanical hard-drive, but the Aria Dominator 560Ti utilises a Kingston SSD Now as the main OS drive and boy does it make a difference.Â
The Aria Dominator 560Ti annihilates our bench rig. If this was a boxing match then our HDD equipped bench rig is Audley Harrison and the SSD equipped Aria Dominator 560Ti is any boxer of your choosing.
Â
Unigine
Finally, as if to gild the lilly, the Aria Dominator 560Ti even gains a couple of frames in the seriously strenuous Unigine benchmark.
If it was possible to bet on such things, I think it’s safe to say you could put your house on what the conclusion will be.
