PC Specialist Vanquish Arc Midi Review
CatZilla
Away from the pure CPU tests to where the majority of use will come, gaming performance, and the R9 290 equipped version has the head upon the GTX770 variant. Both of them perform well of course, with the i5-4670K more than capable of supplying the GPUs with all the data they require.
Unigine Valley
Demonstrating how well the little i5 can push data, you only have to compare the results to our HD7970 equipped 4770K test system, which has 400MHz and hyper-threading as an advantage and yet the PC Specialist Vanquish Arc Midi beats it handily in either configuration.
