YOYOTech Water Dragon 940
Â
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Â
Â
Â
Â
Â
Â
SuperPI is the benchmark of choice for many overclockers as it’s lightweight to download and can give a quick indication on how good a system is at number crunching. A test of 8 million itterations was performed a total of 5 times with the highest and lowest times removed from the results and an average calculated from the remaining three.
Â
Â
Â
Result Observations
Â
Going by the results from Sisoft Sandra and SuperPI, early indications would suggest that the Water Dragon 940 isn’t quite up to the performance of its cheaper counterpart; the Spartan 300. This may seem strange considering the AMD X4 940 used in the Water Dragon is indeed quad-core and overclocked to 3.6GHz (compared to the dual-core Intel E7200 running at 3.5GHz in the Spartan), but a quick glimpse back at CPU-Z reveals that the Spartan 300 has a much higher clocked FSB and Memory; possibly explaining it’s higher performance in these benchmarks.
