Adding a top mounted Window and Fan
Method continued...
Step 2
I use a dremel to do all of my case modding with. If you use a dremel I recommend you use the fiberglass reinforced cutoff wheels, as they will last much longer than the standard ones. When cutting with a dremel do NOT apply too much force as this will break your cutoff wheels.
Let the dremel do the work. If done correctly you should only have to use one maybe two cutoff wheels while doing this project. Once the hole has been cut out use the deburring tool or a file to remove the sharp edges, as these may cut into the rubber moulding.
Cutting the hole
It's a good idea at this time to remove any metal filings that have spread their way through your case. Clean thoroughly!!!
«Prev 1 2 3 4 5 Next»
19-03-2005, 08:17:02
JN
GREAT GUIDE!!!!
Stickied and Repped Quote
19-03-2005, 10:13:53
PV5150
Thanks XMS
PVQuote
19-03-2005, 23:22:23
vice
That's pretty cool. Some day I want to turn all sides into windows.Quote
20-03-2005, 04:21:18
PV5150
Thanks Vice, hope all goes well
PVQuote
14-05-2005, 23:37:44
JNewell_
Great guide, I think this would look great with my case, I'll have to try it sometime Quote
