Aerocool Launches the Xpredator Cube PC Chassis
PRESS RELEASE
Aerocool Advanced Technologies, one of world's leading manufacturers of excellent gaming PC gear, introduces new Cube models from the Xpredator family. The Xpredator series has been very popular all over the world thanks to its outstanding futuristic concept design and a very broad set of useful features. Aerocool takes it to the next level and unleashes the new Xpredator Cubes, which inherit the successful design from the big models and come with many additional features. The Cubes are available as of today in the colors red, black, orange and white.
Aerocool Xpredator Cube is made to be displayed on top of the desk or to be carried to a LAN party, thanks to its fancy appearance and the smaller dimensions of 280 x 418 x 412 mm. The integrated window in the side-panel offers insights on the built-in components. No compromise has to be made when choosing the hardware for the system configuration due to the spacious interior design and the support of both Mini-ITX and Micro-ATX motherboards.
Special effort has been made to allow much easier and convenient mounting process of the system components. Users can simply remove the mainboard-tray when installing the main components, such as mainboard, memory, CPU and CPU cooler. Conventional air-cooling solutions with a height of 187 mm and water-cooling solutions with dual radiators are supported by the Xpredator Cube. VGA cards with a total length of 320 mm can be installed in standard configuration. With the front fan removed, even larger VGA cards with 345-millimeter length are supported.
Mounting process of optical drives, hard drives and solid state disks is simple as well, since both the ODD and the HDD racks can be removed completely. The HDD rack supports tool-free mounting of three 3,5 inch or 2,5 inch drives. Additional two 2,5 inch drives can be installed in the ODD rack under the 5,25 inch bay. In order to support power supply units without length limitations, PSU location has been changed so that the PSU fan faces towards the side-panel. This layout gives more room for cable routing and offers additional cooling possibilities. Up to six fans can be mounted inside the chassis, where two fans are already installed, offering smooth airflow out of the box. One big 200 mm case fan is located in the front, spinning quietly at 800 rpm (53,4 CFM, 26,5 dBA). Another 140 mm model with 1.200 rpm (59,48 CFM, 27,6 dBA) on the rear side hauls out the air. Shell-like vent structure design in the top cover allows users to customize the airflow exhaust furthermore.
The Xpredator Cube chassis feature even more useful functions, such as pre-drilled holes for cable management and water-cooling tubes, a magnetic and removable PSU dust filter, shock-proof rubber pads for 3,5 hard drives and the power supply unit. Last but not least is the well-equipped I/O panel in the top-panel, which offers two USB 3.0 ports, one headphone jack, one Mic jack and an integrated fan controller for fans with up to 15 watts consumption. All Xpredator Cubes are made of especially robust steel with 0,7 millimeter thickness, which are additionally reinforced by utilizing Aerocool's unique side bar design.
All four Aerocool XPredator Cube models are available at etailers and retails starting this week. Suggested manufacturers price is set at $125,90 (excl. Taxes).
Join the discussion on the Aerocool Xpredator Cube on the OC3D Fourms.
«Prev 1 Next»
03-10-2014, 07:53:30
Excalabur50
You are one UGLY MUTHER F...... as Arnie said.Quote
03-10-2014, 08:50:43
Wraith
mmmmmm..... no! No amount of modding can save this all those vents and angles just ruin the aesthetics of what I could see as being a quality watercooled rig. Nice build quality with hideous externals. 5/10Quote
03-10-2014, 08:54:12
Greenback
Normally I would look at the articles you post but I looked at the case and thought only for some1 I hateQuote
03-10-2014, 09:12:58
Tripp
am gonna go there an say it could look great in white, with a custom loop an sleeving and a few tweeks to the case it could look great. i dont like the contrasted colour's thoughQuote
03-10-2014, 09:36:31
paulstung
There is something about it, i just can't put my finger on it. The side mounted psu is a nice touch though, in my M-ATX build that's one thing I though of, it could have done with.Quote
