Alpenfohn Matterhorn Black & White Edition CPU Coolers
22/04/2015, Overclockers UK, Newcastle-Under-Lyme, will be listing the new revision C coolers from Alpenföhn, the Matterhorn black & white edition. Both coolers are finished at the highest manufacturing quality and come with the new 120mm WingBoost2 premium fan. The finish of the coolers means it will be perfect for users looking to build an aesthetically pleasing computer system but without sacrificing performance for visuals.
The Six U-shaped heatpipes have a large contact area to the full copper baseplate to optimise the head-transfer from the CPU.
Suitable for CPUs in socket 2011, 2011-v3, 1366, 115x, 775, AM3(+), AM3, AM2(+), AM2, FM1 and FM2.
Alpenfohn Matterhorn Black & White Edition CPU Coolers  Alpenfohn Matterhorn Black & White Edition CPU Coolers
Key Features
• Trapezoid shaped fins Special shaped trapezoid fins that are placed in a 180º rhythm creating
• Comes with Alpenföhn WingBoost2 Fan With the original WingBoost fans providing excellent results and highly performing in reviews, the WingBoost 2 is designed with a new aerodynamically improved wing geometry providing increased airflow and uprated static pressure at lower noise.
• Permafrost thermal grease for maximum performance Permafrost thermal grease assures the best performance due to a low thermal resistance.
Matterhorn Black & White Specification
ColoursBlack / White
Dimensions138 x 100 x 158mm
Weight1067 g
Heatpipes6 x 6 mm heatpipes
FinsAluminium
BaseplateFull copper base
SurfaceSpecial white coating
Specification WingBoost 2 Fan
Dimension120 x 120 x 25mm
Operating Voltage12 VDC
Airflow106 m^3 / h
Noise18,20 dB(A)
Speed500 - 1500 rpm
ConnectorPWM
You can pre-order the Alpenfohn Matterhorn CPU cooler for £39.99 here
You can join the discussion on the Alpenfohn Matterhorn CPU coolers on the OC3D Forums.
«Prev 1 Next»
