Alphacool release Aurora LED rings
Alphacool has released their new Aurora LED rings for water cooling reservoir illumination. These new LED rings will come in 5 different variants, red, green, blue, white and also UV and come in 40mm and 50mm versions.
This product opens up the option for water coolers to customise their reservoir lighting a lot more than what was traditionally possible, replacing traditional single LED illumination systems with a brighter and more controllable ring system, that slips on the outside of your reservoir and can be adjusted very easily. This also gives users the option to use two or more LED rings on their reservoir, allowing them to light up their reservoir exactly the way they want to.
Installation is completely toolless and the LED strip is powered by a single 3-pin fan header, allowing users to power them from their motherboard, fan controller or directly from their PSU with a 3-pin to molex adapter.
Right now we do not know if users will be able to adjust the brightness of these LEDs with custom fan speed/power profiles.
You can join the discussion on Alphacool's Aurora LED Rings on the OC3D Forums
«Prev 1 Next»
26-05-2016, 14:02:07
Kushiro
That smoke.. mmmmmQuote
