Alphacool releases their Eisbaer 140mm and 420mm liquid coolers
A 420mm AIO liquid cooler!
Alphacool has officially released two new AIO liquid coolers, both of which use 140mm fans. These new AIOs will come in 140mm and 420mm (3x140mm) varieties and come with a design that can be expanded using Alphacool's quick coupling components or even disassembled entirely so that they can be used in a full custom water cooling loop.
These two new models will sit above and below Alphacool's existing 280mm liquid cooler, with the Eisbaer 140 costing €97.95 and the Eisbaer 420 costing €144.95. The radiator used here is a full-copper radiator, with these kits being expandable to include additional radiators and even GPUs.
Features:
- Prefilled watercooler for your CPU
- Quick connectors make it easy to expand and upgrade with Eisbaer Ready
- Pure copper radiator for maximum cooling performance
- DC-LT Ultra Low Noise ceramic pump for whisper-quiet operation
- Refillable via the fi ll port on the reservoir
At the time of writing these coolers will support AM3, AM4, FM2+, LGA 115X, LGA 2011-3 and LGA 2066 sockets. A TR4/Threadripper ready bracket for these coolers will available soon.
You can learn more about Alphacool's Eisbaer range of expandable AIO liquid coolers here.
You can join the discussion on Alphacool's Eisbaer 140mm and 420mm AIO liquid coolers on the OC3D Forums
«Prev 1 2 Next»
