AMD’s Ryzen stock coolers have been leaked
AMD's Ryzen stock coolers have been leaked
AMD’s Ryzen stock coolers have been leaked, showcasing some unique new cooler designs, two of which look like they use Intel-style push-pins.
The largest of these new coolers look like a new variant of AMD’s existing wraith cooler, with the other two fans looking more similar to traditional Intel stock cooler designs. Looking at these images it also looks like these new coolers will feature LED lighting and identical fan designs.
AMD’s Raja Koduri has also been pictured with a system that uses an AMD Ryzen based system, with the cooler coming with purple illumination. With purple LED products being rare, it is assumed that this lighting was achieved using RGB LEDs, which could mean that the cooler uses a 4-pin RGB connection or use some other method of RGB LED control.
You can join the discussion on AMD’s Ryzen CPU stock coolers on the OC3D Forums.
