Anidees release their AI Crystal Cube and AI5S PC cases
The case manufacturer Anidees has now released their new AI Crystal Cube and AI5S Windowed cases in the US and European market, with MSRPs on $139.99 and $79.90respectivelyy in the EU.
Both of these new case designs will come with support for E-ATX, ATX and MATX motherboards, with both cases coming with extensive water-cooling support, with both enclosures supporting 240/280mm radiators in the front and top of the cases.
The AI Crystal Cube chassis will come with front and side tempered glass side panels, which are 5mm thick and are attached to the case using four thumb-screws. The Crystal cube also comes with a 5-way fan hub with 12V (full speed), 5V (low-speed) and 0V (off) options.
This chassis features a dual chambered design where the users PSU, storage (HDDs/SSDs) and cables are kept in a separate compartment from the main system. In total this chassis can hold up to three 3.5" HDDs and 6 2.5" HDDs.
Water cooling wise the tempered glass cube chassis will support radiator/fan combinations that are up to 100mm wide at the front and 65mm wide at the to without any issues.  Users of EATX motherboards will likely need to use smaller radiators at the front of the chassis, though this will depend on the exact dimensions of their motherboard.
Anidees release their AI Crystal Cube and AI5S PC cases  Anidees release their AI Crystal Cube and AI5S PC cases
The AI5S chassis is a more standard PC case design which comes with a single chassis compartment and a PSU cover for enhanced cable management. This chassis will support a single 240 at the top of the chassis and a single 240mm/280mm radiator at the front of the chassis.
On top of the case's PSU shroud/cover the case also has two 2.5" SSD drive mounts, with up to three 3.5" HDD mounts on the rear or up to 7 2.5" SSD mounts.
This chassis will use a standard acrylic window on a steel side panel, with a brushed aluminium effect on the front of the chassis. This case also comes with an 8-way fan controller that comes with the same options as the AI Crystal Cube.
Anidees release their AI Crystal Cube and AI5S PC cases  Anidees release their AI Crystal Cube and AI5S PC casesAnidees release their AI Crystal Cube and AI5S PC cases  Anidees release their AI Crystal Cube and AI5S PC cases
Right now both of these cases are available in the EU on Amazon and at Newegg in the US, with further retail availability at a later date.
Read more on Anidees' new AI Crystal and AI5S PC cases on the OC3D Forums
«Prev 1 Next»
28-02-2017, 08:16:32
AngryGoldfish
I love cube cases.Quote
28-03-2017, 16:44:53
Hobby Gamer
29-03-2017, 20:33:13
NeverBackDown
Originally Posted by AngryGoldfish View Post
I love cube cases.
I hate them lolQuote
30-03-2017, 02:07:23
Hobby Gamer
Originally Posted by NeverBackDown View Post
I hate them lol
Which is good because that's at least one more in stock.Quote
30-03-2017, 02:45:34
NeverBackDown
Was never available for me anyway since it is not sold in the States
So actually it doesn't change anything, good luckQuote
