Antec showcase their Vortex View CPU Liquid cooler
The best-looking LCD-clad CPU cooler? Antec has impressed us with its new Vortex View CPU cooler
We visited the Antec booth at Computex 2025, and the clear highlight was their new Vortex View CPU liquid cooler. The 5-inch IPS screen that covers its CPU block is stunning, and its RGB backglow elevates it to the next level.
The Vortex View will be available in Black and White. Both models feature a 360mm radiator and are cooled by three non-RGB 120mm fans. Antec has invested in premium fans for these coolers to ensure strong performance. In other words, Antec didn’t want their screen to the the only selling point for this new liquid cooling solution.
As mentioned before, this liquid cooler has a 5-inch IPS display with an “addressable backglow”. These elements can be controlled using Antec’s “iUnity” software, allowing users to customise their cooler’s lighting, LCD screen, fan speeds, and more.
The Vortex View will Antec’s first iUnity product, and the release of this product will be defined by when Antec’s software is ready. What we were told at the boot was “we want our software to make our product, not break it.” Clearly, Antec isn’t planning to release this product before it is ready.
The screen on this cooler supports a full 360-degree rotation and can be tilted. This allows users to orient this cooler’s screen to perfectly suit their preferences. Cooling-wise, Antec says that its Vortex View is optimised for airflow and silence and that their cooler has a “performance first” design.
(Image from the Antec booth at Computex 2025)
If Antec’s new AIO’s performance matches its looks, PC builders have a lot to be excited about.
You can join the discussion on Antec’s upcoming Vortex View CPU Liquid Cooler on the OC3D Forums.
