Antec announced their Cube-Designed by Razer chassis
Published: 5th September 2016 | Source: Antec- Via AceModder |
This article was possible thanks to information provided by AceModder on the OC3D Forums.
Antec announced their new Cube ITX chassis, which was designed in partnership with Razer to create a chassis which combines the e-sports design and branding of Razor with the reliability and build quality of Antec products.
This chassis has a green illuminated Razer logo on the front with green LED illumination on the bottom of the case. This case is designed to accommodate a 240mm radiator for GPU liquid cooling and can hold a GPU that is up to 350mm in length. The case itself will be 365 x 250 x 460mm (HxWxD) and fit MITX motherboards with up to 3 rear expansion slots for PCIe devices.
At the base of the Antec Cube, we can see that the PSU section of the chassis is separated, allowing for easy cable management and an overall tidier system aesthetic. The case can support up to four 2.5" storage drives at one 3.5" storage drives, which should be suitable for most DIY system builds.
At this time Antec and Razer have not announced when their Cube chassis will become available or what it's retail price tag will be.
You can join the discussion on Antec's Cube-Designed by Razer chassis on the OC3D Forums.
Antec announced their new Cube ITX chassis, which was designed in partnership with Razer.https://t.co/Ptfvgd7v6q pic.twitter.com/dAyZymgkPG
— OC3D (@OC3D) September 5, 2016
It only looks like a flashlight due to the front LED fan, remove it and non flashlight.
They may be similar in shape but IMO that's the best case Antec have ever made.Quote
