Antec Crown Chassis
Antec Crown Chassis
Published: 12th April 2016 | Source: AceModder (OC3D Forums) |
Antec Crown Chassis
Antec has first shown off their upcoming Crown Mini-ITX PC Chassis in Cebit last month, but now thanks to our forum member AceModder we now have pictures of this new chassis both inside and out, showing both a unique design a clean aesthetic.
Below we can see that the outside of this case is clad in aluminium panels, which are screwed onto the side of the main chassis. It looks like these panels should be available in a variety of colours and should be easily paint-able by any potential modders.
At the left-hand side of the chassis there is the power on button, but other than that there are no external IO options, though users will have very easy access to your motherboard's rear IO.
This case has 4 windows on the front, sides and top, each of which is designed to showcase specific components, with the left window showcasing your GPU, the right window showcasing your CPU cooler and the front window showing your motherboard and SSDs.
Right now we do not know when Antec plans on releasing this case, or what price point they are aiming for, but we do have more pictures of this chassis and its black variant on the OC3D Forums.
Special thanks to Forum Member AceModder for showing this upcoming Antec PC case.
You can join the discussion on see more pictures of the Antec Crown Mini ITX PC Case on the OC3D Forums.
Let's have a look at Antec's upcoming Crown PC chassis. What do you think of the new design?https://t.co/JZDK53OBZ3 pic.twitter.com/V8aBoytJMQ
— OC3D (@OC3D) April 12, 2016
Really liking that internal layout, though. Seems to be very efficient for the water cooling and storage capacity it provides. It's been a while since there was something fresh in this regard.Quote
Here is a crudely paint drawn image of a longer card with an 8pin power connector in orange.
The red arrow shows how the cable will come out and should be right in place.
https://www.dropbox.com/s/3x8hpjl9ea...dnwom.jpg?dl=1Quote
Then again Im not employed to create such things anyways.Quote
