Antec Launches GX300 Entry-level Chassis
PRESS RELEASE
Antec Inc., a global leader in high-performance computer enclosures, power supplies, and mobile accessories today announces the availability of the GX300, the latest addition to Antec's GX series. There is also a version with a window in the side panel available, the GX300 Window. The GX300 is now commercially available from 59€ (suggested retail price including VAT) and is backed by Antec's Quality 3-Year Warranty.
The Midi-Tower is painted black inside and out and features an advanced cooling system as well as rounded upper and lower edges. The GX300 is a clean yet aggressive case with space for high-end graphics cards up to a length of 15.7 inches (400 mm), as well as extra space behind the motherboard tray and routing holes to ensure a neat and tidy build. Thanks to its cutout for the CPU and generous space for cable management, it is fun and easy to assemble a system.
Antec Launches GX300 Entry-level Chassis  Antec Launches GX300 Entry-level Chassis
The top-mounted IO panel allows direct access to the main components, such as USB 2.0 and USB 3.0, Audio jacks, the power button, a fan control switch (high & low speeds) and last but not least an illuminated LED indicator. The GX300 accommodates Standard ATX, microATX, and mini-ITX motherboards and features six tool less drive bays (6x 2.5" bays or 6 x 3.5" bays) for an easy installation, seven PCI-E slots for multi-GPC expansion and supports multiple graphic cards.
The advanced cooling system includes fan mounts for two 120 mm top exhaust fans, a mount for one 120mm rear exhaust fan as well as two mounts for 120mm front intake fans. The chassis features an elevated stand for improved air flow management.
"At a very competitive price, the GX300 offers a lot of features and lets users be prepared for future upgrades", explains Jerome Francois, Sales Director Europe at Antec. "It demonstrates the opportunity to create an up-to-date system with great airflow and space for the latest components."
Specifications
    • Chassis color: Black
    • 6 drive bays (6 x 3.5" / 2.5" drive tray)
    • Motherboards:
    • Standard ATX, microATX, Mini-ITX
    • 7 expansion slots
    • Maximum graphics card size: 15.7" (400 mm)
    • Maximum CPU cooler height: 5.5" (140 mm)
    • Cooling System:
    • - 2 x 120 mm top exhaust fan (Optional)
      - 1x120mm rear exhaust fan pre-installed
      - 2 x 120 mm front intake fan (Optional)
    • Front I/O ports:
    • - 1 x USB 3.0 High Speed USB port
      - 1 x USB 2.0
      - 1 x Audio I/O (HD97)
    • Unit Dimensions:
    • - 485 mm (H) x 180 mm (W) x 475 mm (D)
      - 19.09" (H) x 7.08" (W) x 18.70" (D)
    • Net Weight:
    • - 5.45 kg
Join the discussion on the Antec GX300 case on the OC3D Forums.
«Prev 1 Next»
04-12-2014, 19:56:43
King of Old Old School
another Antec case meh IMO there are better options on the marketQuote
07-12-2014, 08:53:11
Thelosouvlakia
Wouldn't say that. At that price point there aren't many good casesQuote
09-12-2014, 00:07:25
Just my Opinion dude i don't think Antec makes very good cases.Quote
09-12-2014, 03:59:34
barnsley
For £45 you can do much better than this antec case. You've got the NZXT source 210, various silverstone cases, a Corsair SPEC-01 and some Enermax cases.Quote
09-12-2014, 05:09:52
It might depend of the country too but i do agree with you BarnsleyQuote
