Antec Launches New Micro-ATX Case ISK600M
Antec Inc., a leading provider of high-performance computer components and accessories for the gaming, PC upgrade and Do-It-Yourself market, presents a new model of the ISK series, the ISK600M. The case is now commercially available from 84€ (suggested retail price including VAT) and backed by Antec's Quality 3-Year Warranty.
The ISK600M is a compact and robust Micro-ATX case. The durable frame measures 29 cm in height, 27.5 cm in width, and 34 cm in depth. The chassis is made of 0.8 mm cold-rolled steel and features an elegant brushed aluminum front panel. The sophisticated enclosure has space for graphics cards up to 12.5" in length (a total of two expansion slots), a CPU cooler with a maximum height of 17 cm, and six drive bays (three 3.5"bays, three 2.5" bays and one bay for a slim optical drive).
The front panel offers one USB 3.0 and one USB 2.0 port as well as Audio jacks. A total of four fan mounts (three 120mm, one 140mm) ensure sufficient cooling. Perforated side vents on both sides ensure optimal cooling performance. The ISK600M supports ATX standard PSUs as well as liquid cooling solutions. "Our new Micro-ATX case ISK600M features an elegant and sturdy design which will equally appeal to corporate and performance users, but also to gamers looking for a compact build", explains Jerome Francois, Sales Director Europe at Antec. "Its internal space, the advance cooling system and the stylish aluminum panels make this case a safe choice for users who appreciate an understated but advanced design without compromising."
The ISK600M could serve as a conventional PC, gaming rig, or home theatre device and media center, but is also well-suited for professional users and system providers looking for a small-format solution.
Antec Launches New Micro-ATX Case ISK600M  Antec Launches New Micro-ATX Case ISK600M
    • Product Name: ISK600M
    • Case Type: Micro-ATX
    • Front bezel Material: Aluminum + Plastic
    • Color: Black
    • Body Material: 0.8mm steel
    • 1 x Slim ODD bay
    • 3 x 3.5" drive bays
    • 3+1 x 2.5" drive bays
    • 4 x Expansion Slots
    • Compatible Motherboard: Micro ATX, Mini-ITX
    • Graphic card size: ?12.5"(317.5mm)
    • System Fan:
    • 1 x 120 mm rear exhaust fan
      1 x 80 mm rear exhaust fan (optional)
      1 x 140 mm front intake fan
2 x120 mm front intake fan (optional)
    • I/O Ports:
    • 1 x USB3.0
    • 1 x USB2.0
    • Audio I/O (AC97)
    • Product Dimensions:
    • o 290mm (H) x 272.6mm (W) x 340mm (D)
      o 11.4" (H) x 10.7" (W) x 13.3"(D)
Join the discussion on the Antec ISK600M case on the OC3D Forums.
«Prev 1 Next»
19-11-2014, 08:10:25
King of Old Old School
Wow antec is still in the case market i thought they had given up cause how ty the 1900 was Quote
19-11-2014, 13:40:17
A weak offering..... poor cooling options.... pitching at gamers who often watercool/use AIO solutions. Where are the radiator mounting points. Much prefer my Node 804!Quote
19-11-2014, 14:35:59
Looks like Lian-Li's cube lineupQuote
