ARCTIC launches P Pro series Reverse blade fans
Arctic’s P12 Pro A-RGB now have reverse-blade variants
Arctic has released new reverse-bladed versions of its popular P Pro series fans, giving users an improved aesthetic for intake fans with their reversed airflow orientation. These new fans are now available in P12 Pro (120mm) A-RGB forms, with more models to follow.
Currently, the P12 Pro A-RGB Reverse is available as a single fan or as part of a 3-fan triple pack. These are available for €12.49 and €28.99 respectively. White versions of these P12 Pro Reverse-fans will be available soon, as will P14 Pro (140mm) ARGB versions. Non-RGB P14 Pro reverse models will also be made available.
(Image from Arctic)
With its new P Pro Reverse series fans, Arctic plans to offer PC builders improved fan aesthetics while maintaining strong pricing and performance. These fans are well-suited to PCs with panoramic glass front/side panels and side or bottom-mounted fan intakes. These fans match Arctic’s existing P-series fans. All of these fans are PWM-controlled and feature 3-pin ARGB daisy-chaining cables.
You can join the discussion on Arctic’s new P Pro series reverse-blade fans on the OC3D Forums.
