Arctic confirms that their Liquid Freezer series of coolers will support Threadripper
Are any of you considering the use of an AMD Threadripper CPU?
Arctic has announced that their Liquid Freezer series of all-in-one liquid coolers will support AMD's new Ryzen Threadripper series of processors, though at this time it is unknown whether or not these coolers already offer native support of if purchases will require an aftermarket TR4-compatible mounting kit.
These TR4 compatible coolers will come in 120mm, 240mm and 360mm varieties, each of which coming with push/pull fans. The 360mm version will come with a 27mm thick radiator, with the 240mm version will come with a 38mm radiator and the 120mm version coming with a thick 48mm thick radiator.
At the time of writing AMD's Threadripper series of CPUs will release with 12-core and 16-core versions, with a release date that is expected to be before August 10th.
We have reached out to Arctic cooling for clarification on whether their coolers offer native/out-of-the-box support or if users will need to order a "TR4 upgrade kit" from the company.
Update: Arctic has provided us with the following response.
The Liquid Freezer 120, 240 and 360 are compatible and can be used directly with the new processors.
YOu can join the discussion on Arctic's Threadripper TR4 support on the OC3D Forums.
«Prev 1 2 Next»
19-07-2017, 12:27:10
Korreborg
But it can't be optimal with the size of the socket.Quote
20-07-2017, 03:04:06
m2geek
I'm sure there will be some sort of new plate and bracket design for em.Quote
20-07-2017, 03:27:26
Warchild
I think he means the surface area in contact with the CPU IHS will not be optimal. Then again, I think it will be fine.
When you compare previous Intel CPU IHS and the provided stock coolers, you will see the cooler contact does not cover the entire IHS, but merely the crucial center area.Quote
20-07-2017, 03:28:25
NeverBackDown
Well... 16 cores spread out over larger area. I'm fairly certain it's pretty important this time lolQuote
20-07-2017, 03:35:13
Warchild
I still think it will be fine. Just not optimal. I dont think Arctic would dare make such an announcement without having tested this thoroughly. Or perhaps this could be the QA testing slip up of the century.
Perhaps its an evil plan to damage AMDs plot of dominance in the market.
wait, ignore that. I had my tin foil hat on.
I can't wait to see this cpu in action. Even the name just yells at me "this CPU is bad a**"Quote
