Azza's Pyramid Mini 806 is a Showpiece-ready ITX PC Case
Where else are you going to get a Pyramid case?
Published: 4th August 2020 | Source: AZZA |
With an Aluminium frame and tempered glass side panels, this unique case is designed to act as the centrepiece of your setup. This chassis is a smaller version of Azza's existing Pyramid 804 enclosure, offering users support for smaller motherboards, SFX power supplies and discrete graphics cards through the enclosure's included 20cm PCIe extension cable.
This compact PC chassis is due to release this year with early pricing estimates of €249.
Inside Azza's Pyramid Mini 806 enclosure comes support for a single 120mm fan, with Azza including its 120mm Hurricane II Digital RGB fan. In its stock configuration, this enclosure supports two 2.5-inch drives and has a front I/O panel which features a single USB Type-A connection, an HD Audio connector and power/reset buttons.
While this case is far from being the most functional on the market, it succeeds in its design goals. With the right hardware, this enclosure could be the centrepiece of your gaming setup, and thanks to its ITX form factor, it sits within a relatively small 435mm x 368mm x 368mm form factor.
Interested PC builders more about the Azza Pyramid Mini 806 on the case's product page.
You can join the discussion on the Azza's Pyramid Mini 806 ITX PC enclosure on the OC3D Forums.
Just put a pastry snack above the exhaust and it will go well with the movie its playing xD I do like the design on this but it's obviously only for low power systems.Quote
