be quiet goes all-in on its IO product range at Computex 2026
be quiet’s IO investment pays off at Computex 2026
be quiet has invested heavily in its IO Center app and its broader IO ecosystem. At Computex 2026, this investment is now paying off with the release of a broad range of new IO-series products.
Light Wings Pro IO fans
Staring off with their fans, be quiet has new Light Wings PRO IO series fan models, which will be available as single-frame fan setups or as individual 120mm or 140mm fans. These fans can be controlled using be quiet’s IO Controller using their IO Center software. This app can control each fan’s RGB lighting and speed.
be quiet’s single-frame fan designs will be available in 360mm and 420mm forms, with both standard and reverse-blade fan options. Additionally, 120mm and 140mm fan options will be available. All variants will be available in black and white.
Note that these Light Wings Pro IO fans appear to be daisy-chainable and use a custom fan connector. In many ways, these fans feel like Corsair’s newest “LINK” series products.
Meet the be quiet Dark Rock Pro 6 IO LCD
Last month, we reviewed the be quiet Dark Rock 6 and Dark Rock 6 Pro, and soon be quiet plans to launch a new, higher-end model called the Dark Rock Pro 6 IO LCD. Basically, it’s a Dark Rock Pro 6 with an included LCD screen and support for be quiet IO Center control.
The screen on this cooler is a 4.5-inch IPS LCD with 600 nit brightness. The screen can display images, videos, and system information. The relatively high peak brightness of this screen will make its content easily visible to users. be quiet has successfully avoided the problems that using a dim LCD screen can cause.
Dark Power Pro 14 IO
Next, we have the Dark Power Pro 14 IO. This PSU will be available in 1300W and 1600W models and will be 80+ and Cybenetics Titanium-certified. Through IO Center, users of this PSU can monitor thermals, set fan profiles, and change the PSU from single rail to multi-rail mode.
Light Loop IO LCD
Like other IO series products, the be quiet Light Loop IO is designed to be used with be quiet’s IO Center app. It allows users to control this cooler’s screen, pump, ARGB lighting, and fans. These coolers will be available in black and white and in 240mm and 360mm forms.
be quiet IO Centre Software
With be quiet’s IO Centre software, users can control their fan speeds, RGB lighting, and LCD screens from one location. Users can also create custom fan profiles that can be toggled in specific scenarios, depending on whether they want their PC to be quiet or run cooler.
PSU control options are also available in this app, as are control options for be quiet’s keyboards and mice.
IO Center has become be quiet’s everything app, and we expect the app’s functionality to expand over time.
Lastly, be quiet is preparing to launch a new Tenkeyless (TKL) version of its Light Mount mechanical keyboard. If you want to know our thoughts on the full-sized version, you can see our full review here.
You can join the discussion on be quiet’s newest products on the OC3D Forums.
