be quiet unveils its Pure Loop 3 series of CPU liquid coolers
be quiet pairs customisability with aggressive pricing with its Pure Loop 3 series liquid coolers
Earlier today, we visited be quiet’s booth at Computex 2025 and had a gander at all of their newest creations. Among these creations is the new be quiet Pure Loop 3 range, which will be available in RGB and non-RGB flavours. Below we have our full booth tour video for be quiet, which includes everything new we saw from the company at this event.
be quiet Pure Loop 3 LX – More customisation with added RGB
As mentioned, the Pure Loop 3 series will be available in RGB and non-RGB forms. In this case, LX essentially means RGB. These models will have an RGB illuminated pump top and Light Wings LX 120mm fans. This cooler will be available in 240mm and 360mm forms.
What’s neat about the Pure Loop 3 LX isn’t its RGB nature but its customisable pump top. Beneath its clear plastic cover is a removable sheet with a design printed on it. This cooler comes with ten design options, or users can create their own designs to customise this liquid cooler further.
Below are all of the options that ship with be quiet’s Pure Loop 3 LX. These designs can be swapped out in moments.
be quiet Pure Loop 3 – No RGB, More Options
be quiet’s standard Pure Loop 3 features no RGB fans and no RGB LEDs in its pump top. This change makes the standard Pure Loop 3 more affordable, and allows be quiet to release a 280mm version of this cooler in addition to its 240mm and 360mm models. Why? Because be quiet’s Pure Wings 3 fans have 140mm versions, unlike the Light Wings LX fans used with this cooler’s RGB variant.
All of be quiet’s Pure Loop 3 series coolers feature daisy-chainable fans to simplify cable management and a 6-pole motor that’s intended to minimise vibrations/noise. Additionally, all models will feature a fill port that will allow users to top up their liquid cooler with additional coolant.
Pricing
With all models costing under €120, be quiet’s Light Loop 3 series sits on the more affordable side of the liquid cooling spectrum. Be Quiet plans to launch this new series of liquid coolers in August. You can see the be quiet’s preliminary prices below. Sadly, we do not have access to UK prices for these liquid coolers.
You can join the discussion on be quiet’s new Pure Loop 3 series liquid coolers on the OC3D Forums.
