Be Quiet! Announces its First High-end PC Case
PRESS RELEASE
Be quiet!, market leader for PC power supplies in Germany for eight successive years, introduces its first chassis - the Silent Base 800. This case offers generous space and is firmly aimed at the premium segment - for customers who want high end features in a low noise systems. With its innovative design, be quiet! guarantees silent operation while delivering excellent cooling performance. True to the motto 'Form Follows Function', each component in the Silent Base 800 fulfils a specific purpose in order to increase user-friendliness and bring performance to a new level.
As usual, be quiet! puts strong emphasis on maintaining low noise level for its Silent Base800, without any reduction in performance. To achieve this goal, be quiet! has developed innovative front, top and bottom panels that provide intelligent airflow. Fresh air is deliberately drawn into the casing and transported through the interior, increasing cooling capacity compared to conventional solutions. At the same the panels prevent the sound waves from exiting the chassis.
To minimise the noise level even further, be quiet! has covered the side panels and front cover of the Silent Base 800 with a brand new anechoic material. In addition, three award winning Pure Wings 2 fans have been installed, decoupled from the housing. Two of them are 140 millimeter format and have been factory installed in the front panel, another Pure Wings 2 fan with a 120 millimeter diameter has been placed in the rear. This configuration already provides optimal airflow, but that can be increased further with the installation of up to four additional fans and by opening the 3-in-1 air intakes in the side panels.
Optimum space and tool-free installation
The Silent Base 800 offers more than enough space for high-end systems and associated top-class components. Motherboards in ATX, Micro-ATX or Mini-ITX format, heavy-duty tower coolers with a height up to 17 centimeters and long graphics cards can be installed. For 3D accelerators, up to 40 centimeters of free space is available if you remove one of the pair of modular HDD cages is removed. The Silent Base 800 can also be equipped with up to three 5.25" drives, seven 3.5" and four 2.5" drives. The functional structure of the new be quiet! case allows users to install all components without tools. Silicone inserts decouple the hard drives and power supply from the case. There is also the possibility of installing water-cooling with several radiators in the 120- to 280-millimeter range.
 Be Quiet! Announces its First High-end PC Case  Be Quiet! Announces its First High-end PC Case
Stability and optimal dust protection
Weighing in at a significant 9 kilograms, it's clear just how substantial the build quality of this be quiet! chassis is. Measuring a solid 495mm x 266mm x 559mm, the housing has been constructed to an industrial standard. Be quiet! achieves this by using thick steel and high-quality ABS plastic. The manufacturer is demonstrating a new and innovative feature in the side panels: the edges are bent in a U-shape and, together with the newly developed insulation material, form an extremely rugged construction. These factors show that besides a fully functional structure and excellent cooling performance, be quiet! also gave serious focus to the build quality of the Silent Base 800. This is underlined by the numerous dust filters, which are factory-installed on all air intakes.
The Silent Base 800 will be available from November 24th in black/orange, completely black as well as black/silver color combinations at a price of 139,90 USD (excluding VAT) or 119 Euro (including VAT). For the UK the MSRP is 99 GBP (including VAT).
Join the discussion on Be Quiet's Base 800 case on the OC3D Forums.
«Prev 1 Next»
19-11-2014, 23:20:57
giannakos23
it looks a bit like the new 780t from corsair...i don't see this as a bad thing though..Quote
19-11-2014, 23:42:46
Dicehunter
Hardware Canucks have quite a good video out about it, Very very quiet as the name suggests Quote
21-11-2014, 07:30:35
theDTP
Could this replace my Stormtrooper. I think so, one thing I've always loved about the Stormtrooper is where you can mount the pull fans on a 240mm radiator. Same with this case. Might go for an all black theme inside Quote
21-11-2014, 16:00:05
The_Governour
I would say for the price then I dont think this would be a winner here.Quote
