be quiet! revamps their Light Wings range with new White ARGB fans
Great looking white fans for builders who want a quiet system
Be Quiet's Light Wings series fans are now available in white
Today, Be Quiet! has expanded their range of fans with new White models of their Light Wings series fans. We reviewed these fans back in 2021, and we were impressed by their lighting, their noise levels, and their overall performance. With these new white models, we expect the same performance levels as before, but with a new aesthetic.
Based on Be Quiet's press release, which we have included below, these new White Light Wings fans will ship in triple packs and come with an ARGB controller out of the box. These fans will be available in 120mm and 140mm forms, and ship for £59.99/£64.99 for their respective triple packs.
Keeping up with their White aesthetic, these fans ship with white cables and a white RGB controller. The only black things that ship with these fans are their black case mounting screws. The ARGB controller that is provided with these fans can be connected to up to six fans, an all models of be quiet's new White Light Wings fans are PWM controlled.
Press Release - be quiet! Light Wings White: New colour option for award-winning ARGB fans
be quiet!, the German manufacturer for premium PC components, s extending its fan portfolio with Light Wings White. Based on the award-winning Light Wings fan series, Light Wings White offers a new white color option for users looking to build color-oriented systems. All Light Wings White fans offer high-performance, low-noise operation with ARGB illumination and are equipped with one LED ring at the fan’s inlet and another narrow LED ring at the outlet. They are available in four different triple-pack versions: 120mm, 120mm high-speed, 140mm, and 140mm high-speed.
Stylish design with vivid lighting and ARGB hub included
System builders looking at creating all-white builds have a stylish new option with Light Wings White: the fan, cable sleeve and connector are fully executed in white, with a subtle black-on-gray logo to match the color scheme. Like their black counterparts, Light Wing White’s light rings are equipped with up to 20 individually addressable LEDs with a diffuser to spread the light in both directions. This results in a remarkably uniform illumination and impressive lighting effects. Light Wing White is exclusively available in triple packs, which include a white ARGB hub to enable the synchronization of up to six ARGB components in total. The fans can also be connected to motherboards with 5V ARGB-headers and controlled by motherboard software.
Quietness and performance
Light Wings White fans are available in four versions. The PWM models, equipped with seven fan blades and a rotational speed up to 1.700 rpm (120mm) or 1.500 rpm (140mm) are ideally suited as case fans thanks to their low operating noise level. The PWM high-speed models with nine fan blades and up to 2.500 rpm (120mm) or 2.200 rpm (140mm) are optimized for use on radiators or heat sinks. The thick frame and the adapted impeller result in shorter fan blades with optimized angles for a balance between volume and performance for both models. The high-quality robust rifle bearing guarantees a long-lasting and trouble-free operation with a service life of 60,000 operating hours. All Light Wings White fans have a PWM connector that can intelligently control the rotation speed directly via the motherboard.
Pricing and availability
be quiet! Light Wings White triple packs are available in stores from April 11 at the following suggested retail prices:
- Light Wings White 120mm PWM Triple-Pack: €69.90/ $79.90 / £59.99
- Light Wings White 120mm PWM high-speed Triple-Pack: €69.90/ $79.90 / £59.99
- Light Wings White 140mm PWM Triple-Pack: €72.90/ $84.90 / £65.99
- Light Wings White 140mm PWM high-speed Triple-Pack: €72.90/ $84.90 / £65.99
You can join the discussion on be quiet's new white Light Wings ARGB fans on the OC3D Forums.
«Prev 1 Next»
