Be Quiet's Dark Base 900 case will have a reversible motherboard tray
Be Quiet! Releases their new Dark Base 900 case with a removable motherboard tray
Be Quiet! launches their new Dark Base 900 case with a removable motherboard tray
Be Quiet has launched their new flagship gaming chassis the Dark Base 900 and Dark Base 900 Pro, which are both designed to offer as much modularity as possible with removable drive bays, HDD mounts, and even a removable motherboard tray.
The motherboard tray on this case is completely reversible, allowing you to mount your motherboard in either a left facing or right facing configuration, making this case very flexible when it comes to building options.
This case is designed to support up to E-ATX motherboards and can support up to two 5.25" drive bays and 7 3.5" drive bays with ease. Users can remove their 5.25" and 3.5" drive bays if they wish in order to support large water cooling radiators.
    Be Quiet! Releases their new Dark Base 900 case with a removable motherboard tray  Be Quiet! Releases their new Dark Base 900 case with a removable motherboard tray
The difference between the Dark Base 900 and the Dark Base 900 Pro is that the standard version will have a sound dampened non-windowed side panel and the Pro version will feature a 4mm thick tempered glass side panel, alongside built-in Qi wireless charger for mobile phones and RGB LED strips that can be switched between 5 colours be default.
Both versions of the case will come with 3 Be Quiet! SilentWings 3 fans, with a single 120mm fan at the rear and dual 140mm fans at the front.
         Be Quiet's Dark Base 900 case will have a reversible motherboard tray    Be Quiet's Dark Base 900 case will have a reversible motherboard tray
This case will come with a 3-year warranty and will retail at $199 for the base version and $249 for the Pro version with RGB illumination and a Tempered glass side panel.
You can join the discussion on Be Quiet's Dark Base 900 case on the OC3D Forums.
«Prev 1 Next»
03-06-2016, 08:37:39
jimma47
I really like this. A little too large for my own personal use but some really nice ideas.Quote
