BitFenix Spectre Xtreme and Spectre Xtreme LED Fans
Published: 14th January 2016 | Source: Bitfenix |
Bitfenix has just announced their new Spectre Xtreme and Specter Xtreme LED fans, which are designed to deliver high static pressure and be aesthetically pleasing.
These fans feature newly designed fan blades from Bitfenix, offering higher static pressure for use of heatsinks of on water cooling radiators but also to do so quietly.
BitFenix Spectre Xtreme is engineered to be very quiet using high quality Fluid Dynamic Bearings to reduced the noise levels while increasing the efficiency and life expectancy of the fans.
The Spectre Xtreme comes in a wide variety of colours and options, with the black Spectre Xtreme non-LED model and Blue, Green, Red and White LED options, though the LEDs can be turned on and off for these fans with a jumper cable.
Bitfenix say that they have taken special care has been taken to match the Green LED with the light emitted from NVIDIA GeForce GTX stock coolers.
Spectre Xtreme Fans Specifications
Materials Polycarbonate, TPU
Operating Voltage 12VDC
Starting Voltage 5VDC
Bearing Type Fluid Dynamic Bearings (FDB.)
Dimensions (mm) 120x120x25mm
Current (A) 0.28A 12VDC (±10%)
Speed (RPM) 950-2000 RPM (±10%)
Air Flow (CFM) 66 CFM at 2000 RPM (±10%)
Air Pressure (mmH2O) 2.74mm H2O at 2000 RPM (±10%)
Noise (dB-A) 30dB at 2000 RPM (±10%)
Right now there are only 120mm models of these fans on the Bitfenix website, but 140mm versions may be available in the future.
For more information, visit the product pages of the Spectre Xtreme and Spectre Xtreme LED.
You can join the discussion on the Bitfenix Spectre Xtreme and Spectre Xtreme LED Fans on the OC3D Forums.
BitFenix Spectre Xtreme Fans, fans where the Green version matches @Nvidia coolers. https://t.co/CgPG3YZyPj pic.twitter.com/V1Teaf4f35
— OC3D (@OC3D) January 14, 2016
Specs should anyone be interested.
Spectre Xtreme Fans
Noise (dB-A) 30dB at 2000 RPM (±10%)Quote
