Carbide Series SPEC-M2 MicroATX Gaming Case
Need a good MATX Case on a budget. Well Corsair may have the answer for you with their Carbide SPEC-M2, offering both the look and feature set which you would associate with some larger premium cases, but in a matx form factor and a more budget friendly pricepoint.
If you’re building a compact gaming rig with a MicroATX board, you’ve found something special. The SPEC-M2 features excellent cooling and great expansion options. Modern features like USB 3.0 and SSD compatibility, room for full sized graphics cards and PSUs, and an oversized side panel window mean your next rig can look expensive – even if it’s not.
Technical specifications
- Dimensions (L x W x H): 448 x 198 x 378mm
- Maximum GPU Length: 383mm
- Maximum CPU Cooler Height: 150mm
- Maximum PSU Length: 160mm
- Expansion Slots: 4
- 5.25″ Drive bays: 1
- 3.5″ Hard Drive Bays: 2
- 2.5″ Drive Bays: 2
- Fans included: (x1) 120mm fan
- Cooling Layout:
- Front: (x2) 120mm (1 x 120mm included)
- Top: (x2) 120mm
- Rear: (x1) 120mm
- Radiator Compatibility:
- 240mm: Front only
- 120mm: Front, or Rear
- Dust filters for front and bottom intakes
- Front I/O Panel includes: (x1) USB 3.0 port, (x1) USB 2.0 port, Headphone and Microphone jacks, Power on and Reset buttons
Being a small form factor budget oriented design, you would not expect this case to have such extensive comparability for CPU liquid coolers, supporting virtually all Corsair 120mm and 240mm CPU liquid coolers and has plenty of space for Storage drives.
This case is expected to be available at retailers soon.
You can join the discussion on Corsair’s Carbide Series SPEC-M2 Micro ATX Gaming case on the OC3D Forums.
