Cooler Master announce their COSMOS II 25th anniversary chassis
Today Cooler Master has announced a new model in their COSMOS series of cases, with this new design celebrating the companies 25th anniversary with a combination of classic chassis design and modern features.
This new case is called the COSMOS II 25th anniversary edition, which comes with a brushed aluminium aesthetic which is reminiscent of Cooler Master’s ATC-100 chassis from 1999 and also features several modern features like tempered glass side panels.
The COSMOS II 25th anniversary edition comes with unique tempered glass side panels, which are curved to seamlessly match the profile of the chassis while still offering the same car door style swinging doors. These new tempered glass side panels will be available to purchase separately in Q3 2017, allowing owners of the original COSMOS 2 to upgrade.
This chassis will come with an MSRP of £299 in the UK and come with blue LED ambient lighting, with dual 120mm LED fans at the bottom of the chassis and a single 200mm LED fan at the front. There is also a non-LED 120mm fan at the rear of the chassis, which acts as an exhaust.
The COSMOS II Anniversary Edition will also come with a pre-installed blue LED strip and a control panel that can control fan speeds within the chassis and turn the cases LED lighting on or off.
       Cooler Master announce their COSMOS II 25th anniversary chassis  Cooler Master announce their COSMOS II 25th anniversary chassis
You can join the discussion on Cooler Master’s COSMOS II 25th anniversary edition on the OC3D Forums.
