Cooler Master wows us with its MasterFrame 360 Panoramic
Our favourite PC case of Computex? Cooler Master impresses with its MasterFrame 360 Panoramic case
We’ve visited Cooler Master at Computex 2025 and may have already found our favourite case of the event. Cooler Master has a lot to show us at Computex, so expect to see more coverage soon, but for now, we will focus on our highlight. Presenting, the Cooler Master MasterFrame 360 Panoramic.
The MasterFrame 360 Panoramic is part of the MasterFrame series of modular PC cases. Cooler Master has made this series highly modular, allowing users to modify and configure them to perfectly suit their needs. With the Panoramic, Cooler Master has wrapped tempered glass around most of the chassis, making all of the hardware inside visible.
Inside this case, Cooler Master has enclosed a custom liquid-cooled PC setup. Every fitting is polished, every tubing run is well thought out, and every component is mounted perfectly. When glass surrounds your PC on all sides, that calls for a PC where attention to detail is paramount.
Cooler Master’s Panoramic glass surround is made up of three pieces. There are two flat pieces that act as side panels, and a front piece that wraps around both sides of the case. The gaps between these panels are intentional, as this gap enables increased airflow in fully water-cooled PC builds. The airflow pattern of this case is a simple tower pattern. Air enters at the bottom of the case and exits at the top of the case.
Cooler Master’s custom PC build within its Panoramic case contains an odd assortment of hardware. It features an ASUS Z890 BTF motherboard, a Core Ultra 5 245K CPU, and a GeForce RTX 5090. Yes, and Intel Ultra 5 (an i5) with an RTX 5090.
Cooler Master’s Masterframe sets the stage for crazy mods
Alongside their standard “Panoramic” variant, Cooler Master also had a custom “AK Mods X Bounce” version of their new case. This custom case features a stage that features spotlights and a customisable LCD screen. This highlights the customizability of MasterFrame series cases, and what modders could do with the chassis.
There’s a lot of collectors out there, and this case offers PC gamers the potential to display their favourite wares as part of their PC setup. This configuration even allows users to switch out their models and change their background easily, thanks to this case’s LCD screen.
The Cooler Master MasterFrame 360 Panoramic wins 2025’s first “Best of Computex” award
As mentioned before, we are impressed by the MasterFrame 360 Panoramic. If Cooler Master were to offer us one to use/mod, we would take it in a heartbeat. The Warhammer fan in me wonders what kind of diorama I could fit in this “stage” version of this case. The sheer customizability of the MasterFrame opens the door to many possibilities.
What more can I say? This case excites us. We’re excited to see what Cooler Master brings to the table with its MasterFrame series, and we’re looking forward to the Panoramic model in particular. So far, this is our favourite PC case of Computex. That said, we still have many companies to visit before we head home.
You can join the discussion on Cooler Master’s MasterFrame 360 Panoramic PC case on the OC3D Forums.
