Cooler Master announce Master series Liquid Coolers, Fans and Thermal Gel
Cooler Master has announced their Master series Liquid Coolers, Fans and Thermal Gels. Let's have a look at this new product lineup.
MasterLiquid Series AIO water coolers
Cooler Master has been doing a lot of design work into creating their latest generation of AIO liquid coolers, creating a final product that not only provides great cooling performance but also a long life cycle and tool-free assembly.
The pump on these new liquid coolers features a dual chamber design, allowing the coolers key pump components to be kept further away from the heat of your CPU allowing these sensitive components to last longer and offer increased pump performance.
These new liquid coolers will come with Cooler Master's new MasterFan Pro Air Balance fans, offering great airflow and static pressure characteristics.
 MasterLiquid Pro 120MasterLiquid Pro 240
Radiator Size1x 120mm2x 120mm
Radiator Dimensions145 x 118.5 x 38 mm275 x 118.5 x 27 mm
Included Fans1x 120mm MasterFan Air Balance PWM2x 120mm MasterFan Air Balance PWM
Radiator MaterialAluminiumAluminium
Pump Life 50,000 hours50,000 Hours
Pump Power Consumption6W6W
Pump LED ColourBlueBlue
Price £84.99£94.99
Cooler Master announce Master series Liquid Coolers, Fans and Thermal Gel    Cooler Master announce Master series Liquid Coolers, Fans and Thermal Gel
MasterFan series Fans
When it comes to fans there is no single product that is suitable for every workload, sometimes people need fans to direct air into a case whereas at other times it needs to force airflow through a thick radiator or heatsink. Some people are quiet freaks and others are more tolerant of noise if it allows for better cooling performance.
No one fan can suit everybody, but Cooler Master has designed their new Master Fan series to best suit as many customers as possible, giving them 3 adjustable RPM ranges with their easy to use settings switches and offering that are suitable for airflow scenarios, high-pressure scenarios, and intermediate scenarios.
 RPM RangeSettingsLifespanPrice (Inc VAT)
MasterFan Pro Air balance 120mm650/2500
3 x Switch settings
(Silent, Quiet, Performance)
70,000 hours
£12.99
MasterFan Pro Air Flow 120mm 650/19003 x Switch settings
70,000 hours£12.99
MasterFan Pro Air Flow 140mm650/16003 x Switch settings
70,000 hours£14.99
MasterFan Pro Air Pressure 120mm650/27503 x Switch settings
70,000 hours£12.99
MasterFan Pro Air Pressure 140mm650/2800 3 x Switch settings
70,000 hours£14.99
Cooler Master announce Master series Liquid Coolers, Fans and Thermal Gel    Cooler Master announce Master series Liquid Coolers, Fans and Thermal Gel    Cooler Master announce Master series Liquid Coolers, Fans and Thermal Gel    Cooler Master announce Master series Liquid Coolers, Fans and Thermal Gel
Cooler Master MasterGel Thermal Compound
Finally, we have Cooler Master's new MasterGel thermal compound, which is designed to outperform traditional thermal compounds when used on both CPUs and GPUs.
Cooler Master's MasterGel thermal compound is designed to be easily applied and offer easy application and removal whereas their MasterGel Pro thermal compound is designed for more advanced users who want to have the highest thermal conductivity.
 MasterGelMasterGel Pro
ColourWhiteGrey
Thermal Conductivity
W/mK
1.858
Volume1.5ml1.5ml
Accessories1x Scraper
1x Grease Cleaner
1x Scraper
1x Grease Cleaner
Price£5.99£7.99
You can join the discussion on Cooler Master's new Master Series of Cooling products on the OC3D Forums
«Prev 1 Next»
