Cooler Master Announces GeminII S524 Ver.2 CPU Cooler
PRESS RELEASE
 Cooler Master, a leading creator, innovator, and manufacturer of desktop components and peripherals today announces the availability of the GeminII S524 (Ver. 2) CPU and component cooling system in North America. The Cooler Master GeminII S524 Ver. 2 uses a top down cooling method to provide ample airflow to both the CPU and the surrounding motherboard IC chips. The GeminII S524 Ver. 2 also has the added benefit of having enough vertical clearance to support high profile performance memory DIMMs, allowing additional cooling to them as well.
At only 105mm/4.2" tall with a standard 25mm thick fan, the cooler will fit in the majority of desktop cases and even many smaller cases. You can learn more about the benefits of top down coolers at Cooler Master University.
 Cooler Master Announces GeminII S524 Ver.2 CPU Cooler  Cooler Master Announces GeminII S524 Ver.2 CPU Cooler
Accelerated Cooling System
The GeminII S524 Ver. 2 improves on its original design with better performance and utility by adding a copper base to the patented Continuous Direct Contact (CDC) heat pipes. This provides improved surface to surface thermal transfer and exhibits an average 7% temperature decrease.
The GeminII S524 Ver. 2 is designed for most modern system builds and is compatible with both 120mm and 140mm fans. Cooler Master is including its brand new 120mm Silencio FP PWM fan (also found in the Silencio 652S chassis and Nepton 120XL/240M liquid coolers) providing high airflow with sound dampening benefits.
To better utilize this airflow, the GeminII S524 Ver. 2 includes Air-Guides and X-Vent Designs to more effectively dissipate heat. The Air-Guide channels air to spread evenly across the fins. The X-Vents help create low-pressure channels that pulls the cold air completely around the heatpipes in a circular motion for accelerated dissipation.
Availability
The GeminII S524 Ver. 2 is now available across North America. Price and availability may vary based on region.
You can join the discussion on the Cooler Master GeminII CPU cooler on the OC3D Forums.
«Prev 1 Next»
14-04-2015, 06:31:36
carlosandr1
Originally Posted by Watsyerproblem View Post
Cooler Master Announces GeminII S524 Ver.2 CPU Cooler.
http://www.overclock3d.net/gfx/artic...060852933l.jpg
You can read more on the Cooler Master GeminII CPU Cooler here.
Is this better than the Cooler Master Evo 212 ?Quote
14-04-2015, 06:33:06
tinytomlogan
Not really a question that can be answered without testing.Quote
14-04-2015, 06:36:41
carlosandr1
OK thanks anywayQuote
14-04-2015, 06:40:50
Dawelio
This looks funny... looks like a cake which they took the bottom portion away.Quote
14-04-2015, 07:57:16
ander01se
Interesting design, looking forward to the test results!
Would have prefered if the pipes were on the other side so you could put the fan towards the back of the case though.Quote
