Cooler Master announces the availability of their MasterCase Pro 3 chassis
Cooler Master has announced that their new MasterCase Pro 5 chassis is now available for purchase, allowing PC builders to utilise the MasterCase Pro design in the MATX form factor.
With the increasing popularity of compact systems, Cooler Master has made brought their master Case 5 design into MATX form factor, keeping the MasterCase's unique modularity and feature set while still being able to hold large components.
Based on our community research, we found that Micro-ATX motherboards are becoming increasingly popular. People using Micro-ATX motherboards also want a smaller case much of the time. Therefore, we decided to make the MasterCase Pro 3 smaller than the MasterCase 5 series
      Cooler Master announces the availability of their MasterCase Pro 3 chassis  Cooler Master announces the availability of their MasterCase Pro 3 chassis
While the MasterCase 3 is a smaller design it still contains support for a 280mm radiator at the top or front, allowing this case to even accommodate custom water cooled systems.
With the MasterCase design users of the Cooler Master MasterCase 3 will also be able to upgrade their chassis with additional accessories or other custom parts like Tempered glass side panels, LED partitions and even GPU supports.
The Cooler Master Pro 3 is will be available from retailers starting today for £89.99.
You can join the discussion on the Cooler Master MasterCase Pro 3 chassis on the OC3D Forums.
«Prev 1 Next»
13-09-2016, 10:51:08
Chrazey
Pro 3 and Pro 5? Quote
