Cooler Master announces their Wraith Ripper Cooler for 2nd Gen Threadripper processors
Designed for Threadripper, co-developed by AMD
Published: 13th August 2018 | Source: Cooler Master |
This cooler is the result of an exclusive partnership between Cooler Master and AMD, ensuring that this cooler offers full TR4 IHS coverage, support for Ultra-High-End 250W TDP Threadripper 2nd Generation processors and the ability to run quietly under load.
With the Wraith Ripper, TR4 cooler instals have never been easier, thanks to Cooler Master's long-screw mount design, which allows all screws to be accessed from the top of the heatsink. No fiddling with long screwdrivers or hard to reach mounting hardware. Cooler Master's Wraith Ripper is exclusive to AMD's TR4/Threadripper platform.
The heatsink itself is cooled by a single Cooler Master MasterAir Servo fan, which is mounted between two tower heatsinks which sport a total of seven heatpipes and 44mm clearance for DRAM modules. The cooler's illumination is from two addressable RGB strips, which highlight the cooler's frame and a Ryzen Threadripper logo. Users can customise the speed, lighting mode and colour of the Wraith Ripper's lighting using built-in lighting controls or through software.
Cooler Master's Wraith Ripper CPU cooler is set to become available within Europe on September 27th, 2018, for €119, though Cooler Master has warned that pricing and availability may differ between regions.
You can join the discussion on Cooler Master's Threadripper 2nd Generation Wraith Ripper Cooler on the OC3D Forums.
please compare it to the noctua NH-U14S TR4-SP3.
that´s the one i am using right now. the noctua can be bought for ~70 euro so the new coolermaster cooler should be a lot better for 119 euro. |
Quote
