Cooler Master Launches ARGB Hard Tubing Accessory for Custom Water Cooling
With the overwhelming popularity of RGB lighting in today’s PCs, it is easy to see how the technology has made it into almost every modern PC component or accessory, but so far the technology has illuded the world of hardline tubing for custom water cooling setups, though it has invaded most modern CPU or GPU water blocks.Â
Cooler Master has created a custom ARGB lighting solution for hardline liquid cooling setups, an add-on product that is designed to fit around hard tubing. Right now this product is available exclusively in “Asia” and even then in “limited quantities”. Each ARGB Tubing accessory is 3D printed to meet the exact length requirements of custom water coolers, making this a product that could be replicated by anyone with a 3D printer and an RGB LED strips.Â
It is recommended that this lighting solution is used with white coolant, as this will allow the ARGB LEDs to create the lighting effects shown in the above image, as coloured coolant will interfere with the colour of the ARGB LEDs and clear coolant will reveal the ARGB LED strip behind the transparent tubing.  Â
Â
What do you think of Cooler Master’s ARGB illumination tool for Hardline water cooled systems? You can join the discussion on Cooler Master’s ARGB Hard Tubing Accessory on the OC3D Forums.Â
Special Thanks to Dicehunter for the info.Â
