Cooler Master Reveal several new case and cooler designs at Computex
Published: 1st June 2016 | Source: Cooler Master |
Cooler Master has revealed several new cases and CPU cooler designs at Computex, including a new series of AIO water cooling units.
To start it all off Cooler Master will be releasing their new Master Box series of cases, which takes their Master Case concept and brings it to the lower end market, allowing budget oriented consumers to benefit from a lot of the design and aesthetic choices that Cooler Master has made with the Master Case and brings it to a more affordable price point.
Below we can see the Master Box 5, which will be available in both black and white and with several slightly different design options. Both of these are fairly basic cases but offer a clean design and plenty of cable management options.
In the Master Box series, there is also the higher end and gamer oriented Master Box 5T, which comes with a red and black colour scheme and has enough hard drive space to become what could be a decent home server chassis.
There is also the MATX Master Box Lite, which is designed to offer a similar aesthetic but in a smaller more compact form factor. Both of these new cases are pictured below.
Moving onto Cooler Master's higher end Master Case Series, we can see that Cooler Master was not lying when they said that the Master Case concept would lead to a large variety of unique cases and a range of upgrade paths.
Below we can see two new Master Cases, the first being the Master Case 5T, which features a design that is reminiscent of Cooler Master's old Storm Trooper case design and comes in a red and black colour scheme.
Cooler Master has also shown their Master Case 6 design, which has a rear panel for the management of your cases rear cables, allowing you to give your PC and desk a tidy look both inside and out.
For the most part, this case is almost identical to the master Case Maker 5 internally, which is not a bad thing as that case had a great internal layout and design.
Cooler Master has also showcased their new MasterLiquid Pro CPU cooler, which comes with a new pump and radiator design which should offer consumers premium cooling performance in the 120mm, 140mm, 240mm and 280mm radiator form factors.
These new AIO water cooler designs will also come with Cooler Master's new MasterFan Pro fans and MasterGel thermal compound, offering much better thermal performance than Cooler master's previous designs.
You can join the discussion on Cooler Master's new case and cooler designs on the OC3D Forums.
Edited because I was confused with boxes and cases.Quote
