Cooler Master reveals their MasterLiquid FLUX series of AIO Liquid Coolers
Upgraded AIOs that deliver enhanced cooling performanceeeee
Published: 16th December 2021 | Source: Cooler Master |
Cooler Master's latest AIOs have been upgraded to deliver next-gen cooling performance
Cooler Master has just launched a new series of All-in-One CPU liquid coolers, the MasterLiquid Flux series, which have received upgrades that improve all aspects of their liquid cooler design to deliver stronger cooling performance and enhanced heat dissipation.
For starters, Cooler Master has fine-tuned the copper base of their FLUX series coolers to improve heat dissipation, increasing the size of their heat fins while bringing these fins physically closer to the surfaces of modern processors. When combined with Cooler Master's upgraded dual-chamber pump design and motors, Cooler Master's Flow series offers users accelerated heat transfer, which should result in lower load thermals when compared to older AIO liquid coolers from the manufacturer.
Alongside these changes to Cooler Master's pump/base design, Cooler Master has also using redesigned fans to increase air pressure and air intake while maintaining noise levels below 32 dBa at each fan's maximum speed.
Fan upgrades have allowed Cooler Master to increase the fin density of their liquid cooling radiators, allowing the company to boost the surface area that is available for heat dissipation. This allows Cooler Master to more efficiently remove heat from their AIO's coolant, resulting in lower coolant thermals and lower CPU thermals. Cooler Master's MasterLiquid Flux series will be available with 240 mm (PL240 Flux) and 360 mm (PL360 Flux) variants.
Other additions to the MasterLiquid Flux series are the cooler's upgraded Addressable RGB (ARGB) lighting on the unit's pump and base. These units will also ship with a Gen 2 RGB controller from Cooler Master, which can be used with the company's MasterPlus+ software. This software can be used to define the colour of each individual LED.
What follows is Cooler Master's Press Release for their MasterLiquid Flux series AIO liquid CPU coolers. These CPU coolers will become available on January 6th 2022.
PR - Cooler Master Launches MasterLiquid Flux AIO Series
Cooler Master launches the MasterLiquid Flux Series, a performance driven AIO liquid cooling solution. The MasterLiquid Flux Series is the materialization of revolutionary cooling performance. With enhancements from the pump to the radiator and fans, the Flux Series delivers precisely tuned performance for superior heat dissipation and cooling capabilities. The Flux Series will launch in two radiator sizes - PL240 Flux and PL360 Flux.
The MasterLiquid Flux Series has been refined with precision to improve on all aspects of the cooler to deliver the best performance on the market. The new Dual Chamber Pump is more compact than previous generations without sacrificing performance, delivering the perfect volume of flow to pressure for impressive cooling. The high speed motor uses a ceramic bearing impeller to force balanced water flow to and from the radiator for ultimate efficiency of heat exchange. Microchannels have been maximized with ultra-thin spaded fins to accurately target heat spots. The copper base surface area has also been enlarged and optimized with perfect base thickness for further accelerated heat transfer.
The radiator and fans have been upgraded as well, featuring a low profile radiator with superior fin density, coupled with redesigned Flux Series fans. The specifically engineered fans are unique air balance fans with interconnecting blades providing strengthened construction for better stability at high speeds. The inner fan frame rim is angled, boosting air intake, with a frame gap generating increased air pressure for improved cooling.
There is also ARGB incorporated in the fans and pump, with dual loop pump ARGB lighting customizable independently for visual creativity and versatility. Through both the included Addressable Gen 2 RGB controller or Cooler Master's MasterPlus+ software, each individual LED can be changed and adjusted to your liking, whether it is color, effects, or brightness. The Flux Series is the new evolution of liquid cooling, delivering the most advanced cooling capabilities in the market.
Availability:
The MasterLiquid PL240 Flux and PL360 Flux will be available January 6, 2022
You can join the discussion on Cooler Master's MasterLiquid FLUX series of AIO Liquid Coolers on the OC3D Forums.
