Cooler Master show off their colossal Master Case 7
There are already a lot of fans for Cooler Master's new Master Case 5 chassis, but there have been a lot of complaints that the case is simply not large enough to accommodate the largest of components, whether it be large motherboards, water cooling and even large home data storage solutions.
Cooler Master have listened to its fan base and had created a larger variant of their Master Case designs and have called it the Master Case 7 Maker, which has enough space for 3 140x480mm radiators, XL-ATX motherboards and over 12 3.5" drives, making this case big enough for pretty much any PC that you can imagine.
This case sports a large tempered glass side panel which covers the top motherboard section of the case, with a large vented section underneath which has space for a 480mm radiator and provides airflow for the cases PSU and hard drive cages.
Right now we do not have this cases proper full dimensions, but rest assured that this case is gigantic and will surely come with a price tag to match.
You can join the discussion on Cooler Master's colossal Master Case 7 maker on the OC3D Forums
«Prev 1 Next»
03-06-2016, 06:10:33
Warchild
Link takes you to the photo.Quote
03-06-2016, 06:11:23
WYP
fixed. Quote
