Cooler Master teases their MasterLiquid Maker 240 CPU cooler
Cooler Master is entering the custom liquid cooling market!
Published: 20th November 2017 | Source: Guru3D |
Cooler Master revealed their upcoming liquid cooling lineup at Computex 2017, showcasing their own fittings, radiators, pumps, reservoirs and CPU blocks. The MasterLiquid Maker 240 is a CPU liquid cooling kit that offers an option that sits between a fully custom loop and a standard AIO, offering custom water cooling components in a single box that delivers everything that newcomers the liquid cooling scene requires.
Looking at this image, Cooler Master will be delivering this kit with two 120mm RGB illuminated fans and what is likely to be clear coolant with a pink die option.
At this time the exact pricing and release date of this kit are unknown, though it is expected to cost under $200 and support all modern CPU sockets with the exception of Threadripper.
You can join the discussion on Cooler Master's MasterLiquid 240 CPU cooler on the OC3D Forums.
I guess it all comes down to price...Quote
