Cooler Master Unveils ML240P Mirage 240mm Liquid Cooler
Meet Cooler Master's new 'Pro-Level' AIO Liquid Cooler
At CES 2019 Cooler Master officially unveiled their new Mirage series of All-in-One (AiO) liquid coolers, offering addressable RGB illumination as well as a "mirror-like" pump design that allows users to see the unit's impeller in action.
Looking at the cooler itself we can also see that Cooler Master has made some significant changes to their AiO's adding small details to their pump top and their fan shrouds to make them all more visually appealing, especially when RGB lighting is at play within the user's system. The subtle lines across the pump top and the deep, reflective black of the cooler's ARGB fans serve to highlight their forms when used with custom lighting setups.
What we see in the image below is the MasterLiquid ML240P Mirage, Cooler Master's new "pro-level" unit, where the unit's illuminated impeller acts as one of the component's unique selling points, as users will be able to see whether or not the pump is active at any given time, provided that the cooler's ARGB LEDs are enabled. This will act as a useful safety feature in the event of pump failure, and as a neat aesthetic feature when everything is running as it should.
Cooler Master plans to release their MasterLiquid ML240P Mirage in March 2019 for $139.99. European and UK pricing has not been confirmed at this time.
You can join the discussion on Cooler Master's MasterLiquid ML240P Mirage Liquid Cooler on the OC3D Forums
«Prev 1 Next»
