Corsair release their new ML series fans
Corsair has released their new ML series fans which feature replaceable coloured corners and full PWM control. These fans will be available in Red, blue and white LEC versions as well as an all black or a gray and black design.
Corsair's new ML Pro fans use Magnetic Levitation (ML) technology in order to minimise motor noise and provide both great static pressure and high airflow with a lower noise output, effectively combining their previous AF and SP series fans into a single quieter product.
These new fans will be PWM controlled to speeds of up to 2,000 RPM, allowing them to deliver high performance and low noise levels. Corsair's ML fans will also be available in 120mm and 140mm models and feature colour coordinated corners for their LED model fans.
 The ML-Series uses Magnetic Levitation bearings which dramatically cut down on friction. Translation? They’re quieter across the entire RPM range. So you can crank up the speed without cranking up the noise.
The replaceable corners for these fans will be available to purchase separately, though the LED versions of these fans will come with matching coloured corners.
Right now these fans are available to order at select retailers for the price of £18.95 for a single 120mm LED fan and £21.95 for a single LED 140mm fan. Dual packs for the plain non-led 120mm and 140mm fans are available for £21.95 and £24.95 respectively.
You can join the discussion on Corsair's ML series fans on the OC3D Forums.
«Prev 1 Next»
11-07-2016, 17:21:46
Dicehunter
I have 5 x 140mm white LED versions on my wishlist, I hope we can somehow get all black rubber corners as the white would really not go with my setup.Quote
11-07-2016, 21:28:43
King of Old Old School
I wouldn't count on it Quote
