Corsair releases their 275R Tempered Glass Mid-Tower Chassis
A minimalistic design with direct air path cooling and extensive water cooling support
Published: 6th March 2018 | Source: Corsair |
This chassis will ship with both white and black version, allowing the enclosure to suit your personal style. The frame also offers all of the modern design features that builders expect like a front to back PSU shroud, a direct airflow cooling path and enough space behind the motherboard tray to deliver easy cable management options.
Like most modern case designs, the 275R doesn't support 5.25-inch optical drive bays, giving the 275R a clean front with and also opens up the front of the chassis for use with large water cooling radiators. The enclosure supports motherboard sizes from MITX to ATX, with a maximum GPU length of 370mm and a maximum CPU cooler height of 170mm.
Water cooling-wise the "75R is no slouch, supporting up to a 360mm or 280mm radiator at the front of the and up to a 240mm radiator at the top of the case, making it suitable for most modern water cooling setups with relative ease.
Up to three 120mm fans or two 140mm fans can be installed at the front of the 275R, with up to two 120mm fans at the top of the case and a single 120mm fan at the rear. This design should provide more than ample cooling for any modern gaming PC.
On the storage side, the 275R supports up to three 2.5-inch storage devices and two additional 3.5/2.5-inch drives. The two 3.5-inch drive bays are expected to be removable, allowing users to install ultra-long power supplies, or a create more space for a larger front radiator if needed.
On the 275R's I/O, users can connect up to two USB 3.0 devices, as well as standard audio in/out jacks, standard power and reset switches are also provided.
Corsair lists the MSRP of this chassis at £79.99 on their website, with a two-year warranty in case users have any issues. The case will ship with two 120mm fans at stock, neither of which is RGB enabled.
You can join the discussion on Corsair's new 275R chassis on the OC3D Forums.
Another plain box with sub-par airflow in a market full of plain boxes with sub-par airflow. Can modern case design get any worse?
Every case today starts to look more like an exact copy of Fractal Design Define series lol...
Edit:
Watching reviews on this. This case is a joke. Just reinforces my opinion on Corsair cases getting worse and worseQuote
And yet FD is the only one who can actually make a case that has airflow. Who woulda thunk
Edit: Watching reviews on this. This case is a joke. Just reinforces my opinion on Corsair cases getting worse and worse |
As for the allan key glass cover. Don't see an issue there. I prefer low profile screws than some flashing colour plated bulging, bulge poking out. I think Coolermaster got their doors perfect on the C700P. No screw attachments at all. Just a magnet door mechanic.
I saw smaller... but let's see that damn Slate case come out already. It's inevitable and I want's one
