CRYORIG Release their H7 CPU Cooler
PRESS RELEASE
CRYORIG Release their H7 CPU cooler.
CRYORIG, innovator of PC thermal peripherals has released the H7. The next step in CRYORIG's H series heatsink, the H7 holds an even smaller footprint while keeping an extremely high performance efficiency. Keeping almost all award winning features from the larger H5 Universal, the H7 packs great value in it's small size. Featuring series moniker HiveFin technology for better air management and also CRYORIG's much renowned Zero RAM Interference design among many others, the H7 will also feature CRYORIG's brand new QF120 Balanced 120 mm 330~1.600 RPM PWM fan with Quad Air Inlet technology.
The CRYORIG H7 is the next piece in CRYORIG's quest for PC thermal solution dominance. Targeted at entry and mainstream systems, the H7 brings affordability and CRYORIG innovation to the masses. With a total height of only 145 mm, the H7 is almost certain to fit 99% of all mainstream mid-tower cases. While Zero RAM Interference allow users to use any RAM of choice, with no compatibility issues period.
 CRYORIG Release their H7 CPU cooler.  CRYORIG Release their H7 CPU cooler.
With the H7, CRYORIG went back to the drawing board for an even simpler mounting system. The brand new X-Bar System needs even less individual pieces and even less steps to install. Literally install your H7 within minutes of opening up the box. Multi-platform support for both Intel and AMD is already included, and does not require separate parts. A dedicated backplate made from fiberglass augmented PBT, for higher tensile strength, resistance to heat and is more easily recyclable than other plastics. The backplate protects the mainboard from excessive stress that may come from the mounted heatsink, and also provides a solid base for your fast and secure installation.
The H7 is an accumulation of years of design and testing all condensed into a total miniature package. CRYORIG's new H7 is scheduled to be released January 12th in the USA, Japan and Taiwan for 34,50 USD, 5,000 JPY and 990 NTD respectably. Other regions in Europe and Asia will soon follow in February 2015.
For more information, visit the product page.
Thoughts
As much as many of us like AIO or custom water cooling loops, the simple fact is that in many cases these units are both overkill and not very cost effective, at least in the low end. This is where budget CPU coolers like the the Be Quiet Shadow Rock Slim  or any iteration of the Coolermaster Hyper 212 come in, which will be enough to cool most Systems and will remain aesthetically pleasing. It is great to see CRYOTEK moving into this market segment, especially with a cooler which looks this good.
At present we do not know what the price will be in the UK, but expect it to be around £25-30 price range.
You can join the discussion on the CRYORIG H7 CPU Cooler on the OC3D Forums.
«Prev 1 Next»
12-01-2015, 14:40:42
Thelosouvlakia
This price range is filled with units that either are innefective and.or look fugly.
Let's hope this is not one of theseQuote
12-01-2015, 14:51:27
AverageNinja
These look quite decent, especially for the price. I'd be very interested in seeing a review on this one, and the R1 Ultimate.Quote
12-01-2015, 15:01:57
Dark NighT
The unit itself doesnt look to bad, but that mount indicates a one stage mount, which either means removing the mobo or be skilled enough to mount it in the case while using the other hand to tighten the screws.Quote
13-01-2015, 03:05:19
jackjack
I like the design with that price i think it's hard to ignore, let see the review TomQuote
13-01-2015, 06:54:52
jaspervandervalk
Yeah the unit looks quite clean and nice, especially for the price as has been said above lets hope the performance matches the high standards set for design and price!
JasperQuote
