CRYORIG teases two new ITX PC Cases
CRYORIG has teased two new ITX PC Cases that are bound for Computex 2016, both of which offer some innovative designs.
The first of these two cases in the Mac Pro inspired OLA, a cylindrical PC case that can house standard PC hardware, unlike the Apple Mac Pro that is designed to house specifically designed Apple components.
This case can house an MITX motherboard and a full sized GPU, though the case only will support small form factor CPU coolers and CPU coolers that have a TDP of under 100w. This case can also house a single 3.5" drive bay and a single 2.5" drive bay, or alternatively dual 2.5" drives. This case will only support SFX sized power supplies.
At the top of this case a specifically designed 140mm exhaust fan pulls heat up and out of the chassis.
  CRYORIG teases two new ITX PC Cases  CRYORIG teases two new ITX PC Cases
The second case that Cryorig had shown is the MITX Taku case, which is designed to act as a monitor stand/PC case features a minimalist design.
The PC case itself is inside a drawer section of the unit, which can be pulled out even when a monitor stands on top of the chassis, making your components easily accessible.  This case can also support GPUs that are up to 240mm in length.
Below are the specifications of both these new cases, which will have prototypes on show at Computex. The Ola and Taku are planned to be launched in late 2016 and early 2017 respectively.
You can join the discussion on Cryorig's Ola and Taku cases on the OC3D Forums
«Prev 1 Next»
24-05-2016, 09:05:40
CreatiXx
they both look awesome imo! but what about heat? :/Quote
24-05-2016, 09:13:08
barnsley
I really like both cases. Its a shame about the lack of CPU cooling options or fan mounts. The Ola is right up my street.Quote
24-05-2016, 09:19:33
SuB
Not gonna like that Taku case has audio-stack written ALL over it. That'd look swoosh as hell under my Silver Amp...Quote
24-05-2016, 09:46:33
Surpuppa
Audio-stack?Quote
24-05-2016, 09:49:18
Warchild
Are we moving away from towers and going back to the good ol desktop pcs with monitors planted on top? Quote
